Vortech Intercooler bracket is poorly designed
Old Jul 22, 2007 | 11:10 PM
Triple8Sol's Avatar
Triple8Sol
Default Vortech Intercooler bracket is poorly designed
The heavy intercooler only comes with one bracket for the passenger's side. Of the two holes on the side that mounts to the support beam, only the top hole lines up with a hole to thread in a bolt. The bottom hole doesn't have threads, so I think I'll have to find a bolt/nut combo that fits, and just sandwich the bottom hole on the bracket.
The driver's side doesn't even have holes to mount another bracket. I'm considering possibly drilling a hole and threading it, then fabbing a custom bracket.
What are you guys doing right now? Did you just install it the way it came?
Old Jul 22, 2007 | 11:32 PM
DMK's Avatar
DMK
Yup, noticed the same thing when I installed mine. The intercooler isn't very heavy, so the brackets it rest on do the job fine. You can of course weld the bottom brackets for better stability, but I have never had a problem with the way it was setup.
Old Jul 23, 2007 | 04:19 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
there are actually two brackets that go under and hold it from the bottom as well...
remember the two silver pieces that you didnt know where they went
they are the same color as the one that goes on the side...
Old Jul 23, 2007 | 07:25 AM
Triple8Sol's Avatar
Triple8Sol
I saw them in the instructions, but I bought the kit used and they're not in there. Are they metal or plastic? Also, in the instructions, those two brackets are only used to hold the intercooler in place while you line it up and tighten the single bracket on top. Instructions say to remove them after you're done.
Old Jul 23, 2007 | 07:51 AM
Jay'Z's Avatar
Jay'Z
OP how da hell do you have 110 itrader?? u have an online business?? lol.. thats the highest ive seen on here..
Old Jul 23, 2007 | 08:05 AM
RA11325's Avatar
RA11325
cuz Triple8 is a badass, the bracket is fine, the intercooler is not very heavy.
Old Jul 23, 2007 | 08:10 AM
Hexxum001's Avatar
Hexxum001
The brackets (as long as all the parts are there and installed correctly) are more than fine to hold the IC.
Old Jul 23, 2007 | 09:29 AM
DMK's Avatar
DMK
Sorry, I thought you had them. There are two metal rectangular brackets the hold the intercooler from the bottom. It just bolted down on one side and the other side is left free for the intercooler to rest on.
Old Jul 23, 2007 | 04:58 PM
dlt1cy's Avatar
dlt1cy
I have over 30k miles with only the side bracket. No problems to date. I took the lower two brackets off after 2k because they were rubbing grooves in the bottom of the ic.
Old Jul 23, 2007 | 09:05 PM
Blackbird CPV35's Avatar
Blackbird CPV35
the pipes and silicone hose give enough support to the ic along with the side bracket, no need for another bracket
Old Jul 24, 2007 | 11:13 AM
Triple8Sol's Avatar
Triple8Sol
I thought about ordering up those 2 lower brackets, and just leaving them on like some of you did, instead of removing them as the instructions advise. Can you show us a pic of the grooves that got rubbed in? Or explain them in more detail? Thanks.
Old Jul 25, 2007 | 12:33 PM
dlt1cy's Avatar
dlt1cy
They were just scratching the crap out of the bottom of the i/c, so I removed them. I'll try to get pics.
350Z_Al
Oct 29, 2020 07:44 PM
kyin
Oct 15, 2015 05:54 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
Dymsi
Sep 29, 2015 11:32 AM
