mounting o2 sensor on stock cat
Old Jul 23, 2007 | 09:34 PM
zeer0's Avatar
zeer0
Default mounting o2 sensor on stock cat
Hi I was wondering if anyone has any pics of their wideband sensors mounted on their cats. I have read a couple threads about people who have done that, but have not seen any pics. When I got my current o2 sensor installed, the guy at the shop was hesitant to torch a hole into the cat so he did it on the Y-pipe. I want to upgrade my exhaust soon so I want to have a tap on the cat first before I upgrade. Thanks
Old Jul 24, 2007 | 06:51 AM
westpak's Avatar
westpak
SFZCC
after the cat it is useless needs to be before the cat.
Old Jul 24, 2007 | 07:05 PM
zeer0's Avatar
zeer0
How did you get your sensor mounted on before your cat? There is no clearance till you get to the cat. I've been running with my sensor after the cat for a while now and it seems fine. The cars probably running a little richer than the sensor reads but thats ok with me.
Old Jul 25, 2007 | 01:22 AM
mthreat's Avatar
mthreat
I have my O2 sensor (for my wideband guage) on the exhaust manifold, just before the cat.
Old Jul 25, 2007 | 03:54 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
you can weld it at the top of the drivers side cat just fine, just mark it before you take it out so you can see if it will clear any parts. then just take it down and have a bung welded on it...
Old Jul 25, 2007 | 05:42 AM
westpak's Avatar
westpak
SFZCC
Sorry don't have cats only test pipes so install is easy.
Old Jul 25, 2007 | 07:27 PM
rcdash's Avatar
rcdash
there is room for bungs pre-cat. what is harder is orienting them to tilt downward to prevent moisture accumulation (as recommended by Bosch).
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
EnjukuRacing
Drivetrain
Sep 14, 2015 11:15 AM
