My baby went boom...
Old Aug 13, 2007 | 02:44 PM
  #101
diwun67's Avatar
diwun67
Originally Posted by freezeg35
So excuse my ignorance, but with open dump(s), is it just like running a car without and muffler or does the turbo quiet it down some. I am entertaining the idea down the road, but am concerned about how loud it will be as i have never heard a car with open dump(s).
Thanks.
It gets loud, but only under partial to full boost. I sometimes wonder if I just got a cops attention when I romp on it...
Old Aug 13, 2007 | 03:22 PM
  #102
rmezz13's Avatar
rmezz13
with that many miles and a dream of F/I you should have went with a safer more reliable route. A supercharger would have been a better pick but i would personally have stayed N/A and started out by building the heads or buying some heads already built then while you have the heads off just build the whole motor and buy a stroke kit. Would have cost more than a bolt on turbo but would have saved you the headache now. and possibly the money you'll spend now.
Old Aug 13, 2007 | 03:27 PM
  #103
mario23's Avatar
mario23
I disagree. You can run a properly tuned FI setup on a stock engine with the proper tune. Many here are doing it. I haven't had any problems. I'm saving up for a build later on down the line when I feel I need more power, but I'm extremely happy with it now. It would be nice to build first, but honestly I didn't have that kind of time/money .
I wanted boost!!!
Old Aug 13, 2007 | 03:33 PM
  #104
diwun67's Avatar
diwun67
I wanted boost!!!
The boost bug bit me bad
Old Aug 13, 2007 | 03:55 PM
  #105
mario23's Avatar
mario23
I know...when it finds you...there's no where to hide
Old Aug 13, 2007 | 04:41 PM
  #106
DaveFunction2ND's Avatar
DaveFunction2ND
Originally Posted by MIAPLAYA
Better question, where was the UTEC Map sensor pulling its pressure signal from?
From the front intake plenum port.
Old Aug 17, 2007 | 08:32 AM
  #107
Twon's Avatar
Twon
my buddy says to sell the turbo kit and worry about getting a motor. he said to safely run the TN kit on my stock engine, i have to turn boost down to 4 or 5 psi....i see plenty of people on here with stock motor running 8psi...
thoughts?
Old Aug 17, 2007 | 09:14 AM
  #108
MIAPLAYA's Avatar
MIAPLAYA
thoughts?
Thoughts? Your buddy is wrong. Over 70k miles and 2 years and still running strong on 8 PSI..
Old Aug 24, 2007 | 05:00 AM
  #109
EM-EFER's Avatar
EM-EFER
Just wondering if your Grandma helped you with the installation of the Turbonetics kit?
Old Aug 24, 2007 | 05:09 AM
  #110
Cux350z's Avatar
Cux350z
hatersgonnahate
^rofl!
Old Aug 24, 2007 | 05:23 AM
  #111
Julian@MRC's Avatar
Julian@MRC
A couple of things we see wrong here.
1)Turbonetics kit with aftermarket exhaust
2)Aftermarket boost controller
3)Motor with 100,000+ miles
4)Unkown A/F and timing at WOT
All a recipie for disaster in my opinion.
Good luck with the build, sound like you went lean and snaped a rod.
Old Aug 24, 2007 | 05:24 AM
  #112
Julian@MRC's Avatar
Julian@MRC
thoughts?
Your buddy, is he a mechanic? Did he do the install?What are his qualifications?
Old Aug 24, 2007 | 07:04 AM
  #113
MIAPLAYA's Avatar
MIAPLAYA
Whats wrong with a Turbonetics kit with an aftermarket exhaust. I guess me and everyone else who runs like that with no issues is at risk too? Its too bad your public apology doesn't extend to shamelessly calling out a manufacturer for a user mistake...
Old Aug 24, 2007 | 07:23 AM
  #114
Motormouth's Avatar
Motormouth
I think he meant not tuning for a different exhuast then what the reflash Turbonetics gives expects to have (stock exhuast).
does that make it less like an attack?
Old Aug 24, 2007 | 07:24 AM
  #115
Jay'Z's Avatar
Jay'Z
LMAO..
Old Aug 24, 2007 | 07:29 AM
  #116
MIAPLAYA's Avatar
MIAPLAYA
I'm still not seeing an issue with running with an exhaust. I and at least 30 other people on this board have done so no problem...
Old Aug 24, 2007 | 07:30 AM
  #117
taurran's Avatar
taurran
You shouldn't need to tune for a change of exhaust.
I've already accepted the fact that MRC hates anything Turbonetics and anything he says will be biased. Therefore, I will not argue.
Old Aug 24, 2007 | 10:22 AM
  #118
Julian@MRC's Avatar
Julian@MRC
Well, I will say that the last TN kit we saw with a custom 3" exhaust, and he did have a plenum also,I should have mentioned that..Ran at almost a 13.0 A/F under boost(9-10psi) on our dyno.The kid was advised to retune for the mods or put the stock stuff back on.
He did not listen, and 2 weeks later a flatbed dropped his car off in the middle of the night with a bent rod.
I was not bashing TN, your assuming I was. What I am saying is that the kit was designed for a stock car. when you alter the airflow in and out of the car, you obviously will alter the state of tune.This is basic tuning 101.
The OP case may have been install related also, we simply do not know.
Please calm down.
Old Aug 24, 2007 | 10:27 AM
  #119
Julian@MRC's Avatar
Julian@MRC
Oh really.I did not know that. I was under the assumption that the TN kit was designed to run 7psi on a stock car. All of my training and experiences tell me that when you alter the amount of air a vehicle is allowed to flow,especially a turbo charged one,you will in fact alter the tune...
I have opinions on certain products, yes. However I was in no way attempting to bash any TN product.I was simply looking at the facts in this particular case and combining them with past personal experiences, to make an educated guess in what actually happened. There is always 3 sides to a story, the "A" side, the "B" side and what actually happened. The kid did say he had an aftermarket boost controller on the car, which to my knowledge the TN kit utilizes a stock WG spring as boost control at 7-8 psi, although we have seen some nasty boost creep from time to time, even with the overboost correction kit.
Old Aug 24, 2007 | 11:09 AM
  #120
MIAPLAYA's Avatar
MIAPLAYA
Please calm down.
Fair enough...
