My baby went boom...
Old Aug 9, 2007 | 04:41 AM
Twon's Avatar
Twon
Unhappy My baby went boom...
8 miles...thats all the further i got. the turbonetics kit is too much for the stock motor. this was really disappointing actually, my car just got done and i was so excited...then a hard pull blows it. my buddy is further investigating tonight, but we know theres a hole in the block somewhere.
i guess its time to search for a new motor? $1000 about...
no other way to go than to build if you ask me now, so itll sit til thats done. last night was a very long, late night
Old Aug 9, 2007 | 04:43 AM
zpeedDemon's Avatar
zpeedDemon
damn that sux bigtime. if your going to build your motor do it right and get stronger parts.
Old Aug 9, 2007 | 04:44 AM
cheshirecat79's Avatar
cheshirecat79
was it ever tuned after the install?
Old Aug 9, 2007 | 04:46 AM
Ruthless18x's Avatar
Ruthless18x
holy **** that sucks dude. all this at 8psi?
Old Aug 9, 2007 | 05:21 AM
Well at least you had 8 miles to enjoy the thrill of forced-induction.
Old Aug 9, 2007 | 05:23 AM
Lawy'dU's Avatar
Lawy'dU
this is why a proper installation and tune is critical for FI. sorry bro. Good luck of the build.
Old Aug 9, 2007 | 05:28 AM
MR RIZK's Avatar
MR RIZK
That is one long burn out !!
Old Aug 9, 2007 | 06:19 AM
PM-Performance's Avatar
PM-Performance
Sorry to hear this, but you did not do something right.
Plain and simple. If it blew in 8 miles, something else was going on or not going on in there. The turbo just helped it surface quicker
You will realize that tuning is key on any turbo car. Esp a car that wasnt turboed from the factory.
Old Aug 9, 2007 | 06:21 AM
THE TECH's Avatar
THE TECH
Wow, quickest failure on the TN kit. Was a tune done before you decided to take it WOT?
Old Aug 9, 2007 | 06:51 AM
BlueBallZ's Avatar
BlueBallZ
dam man, that sucks, i have a turbonetics kit on my 2006 350z and im boosting at 10psi's for the last 1200 miles, i would say 900 of them were driven hard..but good luck with ur car man
Old Aug 9, 2007 | 07:38 AM
Twon's Avatar
Twon
a reply to all that asked:
no. we took it out for one ride, just to make sure everything was running properly. all it took was one hard pull to blow it. all i had done was the reflash done by turbonetics. this next time, it will be fully tuned before performing any pulls whatsoever.
im still afraid it wouldve blown on a dyno as well, but then again im not sure because i havent watched a car be dyno tuned.
the motor had 103,000 -> i dont know if this could add to the cause or not.
ive seen motors with 40K - 50K for $1000 - $1100 so after i get that, ill go from there. i didnt plan on needing extra money for something like this, so im going to be strapped (motor, better build, tuning) but we'll see how it goes.............very disappointed
Old Aug 9, 2007 | 07:41 AM
THE TECH's Avatar
THE TECH
Wow, lotta miles. I woulda had the motor checked before installing the kit.
Old Aug 9, 2007 | 07:42 AM
PM-Performance
you dont just turbo a car and do a pull to see how it does.
you drive around at part throttle and make sure that looks good. view timing and AFR.
Then start to ease into boost a little and correct the fueling and timing from there before doing a hard pull.
The shop that did this work should know better.
Turbos are great fun as long as you do enuff research and know how important tuning is.
Dont feel soo bad. I blew a $5k built bottom end at about the 1/8th mile marker on my first pass with it. I had it tuned and just something went wrong and it leaned out and popped on the first pass.
Turbo cars deff need more upkeep
Old Aug 9, 2007 | 08:12 AM
RedBullRR's Avatar
RedBullRR
Seems like it wasnt tuned rite. I see a lot of members here running 400whp on a stock block with that kit and no problems.
Old Aug 9, 2007 | 08:15 AM
RedBullRR's Avatar
RedBullRR
What numbers you throwing down? I'm looking to go with this kit from a local guy thats on these forums, just intrested in knowing some details.
Old Aug 9, 2007 | 08:16 AM
Blu_Blur's Avatar
Blu_Blur
A lot of possibilities here and I am sorry to hear this.. I am also a TN owner.
It could be the mileage on the engine (rods) or it could be the fact that you were only using the reflash which has proven to be incompetent.
Old Aug 9, 2007 | 08:18 AM
doug's Avatar
doug
what was the boost gauge showing?
Old Aug 9, 2007 | 08:24 AM
Zexy's Avatar
Zexy
It blew at 8 miles? It was a tuning issue fair and simple. Some detonation was probably a factor. I wouldn't trust the TN flash alone either.
I don't think the "turbo was too much for the stock motor" is a valid explanation. Hope you get it sorted out.
tonester1011's Avatar
tonester1011
CF God
that sux...same thing happen to me with my aps tt...i think mine made it to the 3rd pull on the dyno before a rod snapped in half... good luck with the build.
Old Aug 9, 2007 | 08:37 AM
Chebosto's Avatar
Chebosto
The reflash for the TN kit, is spec'd for STOCK exhaust..
your sig says Tanabe Super Medalion.... free-er flowing ehxaust plus turbo might lead to the over boost issue. won't it?
who installed it?
