Guessing I burnt my AC line TN
Old Aug 9, 2007 | 11:33 AM
andyisphat2004's Avatar
andyisphat2004
Default Guessing I burnt my AC line TN
Just went to have my AC recharged. It was initially holding vacuum 30", but as soon as a charge was put in it, the exhaust started smoking. Must be leaking and the intake was sucking in the refrigerant. I looked but couldnt see the relocation line from the top of the car. Should you be able to see it, or do you have to get under the car to see it?
Old Aug 9, 2007 | 11:48 AM
QuadCam's Avatar
QuadCam
If you are out of your TN warranty, I have a brand new TN 350Z A/C line. It came with my kit, but I needed the G35 spec line.
Old Aug 9, 2007 | 11:50 AM
taurran's Avatar
taurran
Get some UV coolant and charge the system with it. They have kits that come with a UV pen light that you can find the leak with.
Good luck on getting it fixed. Next time, I'd suggest to go overkill with the heat shielding and routing.
Old Aug 9, 2007 | 12:43 PM
blowncob's Avatar
blowncob
your in for some pricy work my friend, i burned up all 3 of my ac lines! so 1600 dollars later now i have nice cold ac!
Old Aug 9, 2007 | 12:59 PM
taurran's Avatar
taurran
Or you could just do the work yourself and be extra careful with the routing. You can have it all done in one day's work. Just buy a case of beer and ask for a friend's help.
Old Aug 9, 2007 | 02:04 PM
boostintt's Avatar
boostintt
great advice... this is just what i did. but it was the upper not the lower ac line that broke.
Old Aug 9, 2007 | 02:06 PM
boostintt's Avatar
boostintt
again the great Taurran speaks the truth....
i ended up takin my turbo out, bought an ac line ($50) and had a friend help me reinstall it.... forgot to get the beer but i got cold ac...
Old Aug 9, 2007 | 02:10 PM
taurran's Avatar
taurran
Yes, and I'd prefer to route it myself to make sure it's done right. I hate leaving something as touchy as that up to someone else.
Oh, and nothing great about giving simple advice, but thanks. lol...
Old Aug 9, 2007 | 06:34 PM
Z PHAT Z's Avatar
Z PHAT Z
My friend just un-installed my TN kit to sell. We found out that the AC line that TN provide with the kit burnt in 1/2. It so burnt that it went thru the line and broke in 1/2
Old Aug 9, 2007 | 06:49 PM
taurran's Avatar
taurran
Whoever installed it did a HORRIBLE routing job then.
Old Aug 9, 2007 | 07:22 PM
THE TECH's Avatar
THE TECH
It's the free A/C mod. Included with every TN kit. HAHA!
Old Aug 9, 2007 | 08:11 PM
andyisphat2004
What is the line made out of, rubber? I am looking at the isntall guide, but it is hard to tell with the sleeve on it. Also what is the easiest way to access this? my guess is removing the turbo?
thanks
Old Aug 9, 2007 | 08:28 PM
TayTaythatsme04's Avatar
TayTaythatsme04
I have a TN kit, but AC ? whats that ?
. . . I just didnt even bother with the AC I just drive with the windows down
T
Old Aug 9, 2007 | 08:33 PM
redman333's Avatar
redman333
T
I did that too for a while but now the Z's at GTM getting a new line put in.
Old Aug 9, 2007 | 08:38 PM
taurran's Avatar
taurran
Replied to your PM.
Get a new one, or even better to get a custom line that's 6-8 inches longer.
A custom shield of DEI "heat wrap" and "cool tube extreme" will keep it from melting through again. Make SURE it's routed well away from any and all piping.
Here's what my custom lower line looks like (8 inches longer and wrapped in DEI heat wrap with cool tube extreme). Needless to say I've got a brick sh1thouse of an AC line:
On my build, we're replacing my upper AC line as well and cutting off the "U" bend in the hardline that runs to the compressor and shielding it with DEI Fire Sleeve.
Old Aug 9, 2007 | 08:54 PM
andyisphat2004
Is the lower line the one that TN supplies with the kit?
Old Aug 9, 2007 | 08:55 PM
MIAPLAYA's Avatar
MIAPLAYA
Yes it is the lower line..
Old Aug 9, 2007 | 09:19 PM
TayTaythatsme04
Im probably going to have GTM take care of that along with a bunch of other stuff when I get back home
T
Old Aug 9, 2007 | 10:15 PM
zcon's Avatar
zcon
Default Jt
should have went to Performance factory
Old Aug 9, 2007 | 10:23 PM
taurran's Avatar
taurran
Yeah, just a short drive from Hawaii...
