Help! APS TT Install Questions!
Old Aug 12, 2007 | 05:42 PM
jining's Avatar
jining
wow sweet thank you
Old Aug 12, 2007 | 08:29 PM
go-fast's Avatar
go-fast
Originally Posted by jining
alright more questions lol, the first 2 are specific only to the g35 install I believe, since its slightly different then the 350z install. I included 2 pictures of my questioned areas.
4 Questions:
1. The LHS turbo discharge pipe and ac condensor seem to be interfering. SHould I just bend this large cylindrical object? Im a bit unclear as to what lines i should bend. The instructions that came with the g35 adaption kit are a bit vague without pictures. I bent the lines a little bit to get it out of the way of the pipe, but this larger AC line is touching the discharge pipe still.
2. Airbag sensor relocation. In the g35 adaption kit instructions it says to remove the stock airbag sensor mounting bracket. It is riveted on so should I Just drill through them or cut the bracket off?
3. Where did you guys mount your fuel pressure regulators?
4. Did you install the inlet duct before the discharge duct? The instructions say other way around but it seems to be much easier the other way around. If not, whats the reason?
PIctures of these questioned areas on a g35 aps tt install would be so helpful!
Thank you for your help!
Ps, my progress, the water lines are in, oil pickup and pan are in, turbos are in and actually bolted in, and oil drain lines are in. Not pulling the motor isnt as bad as I thought.
1.bend the pipe carfully 2.drill the rivets(put wood behind it) 3.firewall,centered to the pass side a little 4.do as instructed so you can reach the clamps later.
Old Aug 12, 2007 | 08:31 PM
go-fast's Avatar
go-fast
Another question, installing the RHS compressor inlet, there is this bracket which is getting in the way, do we bend it or remove it?
Thanks.
remove the bracket
Workshop12
Mar 23, 2020 01:45 PM
bcoffee20
Nov 19, 2015 06:39 PM
Suffolk350z
Sep 13, 2015 02:43 PM
BlinkerFluid
Sep 8, 2015 10:06 AM
