Those w/ Walbro 255 & no fuel return
Old Aug 13, 2007 | 04:26 PM
moog's Avatar
moog
Default Those w/ Walbro 255 & no fuel return
So of course it's better to have a return system, but exactly how many are running w/o one. Any problems? I understand that fuel pressure at idle will be high, but what's the real negative impact of it?
Old Aug 13, 2007 | 04:30 PM
eltness350's Avatar
eltness350
The Untouchable
i would get aam basic fuel return if u dont want to spend alot of money....when i procharged - after 7psi the fuel pressure was all over the place and was real hard to tune...helps cause u can add one psi per psi of boost...so i would negative effect...harder to tune and then u wont get all ur hp u want out of it because it would have to be a "safer" tune
http://www.alteredatmosphere.com/mm5...y_Code=350Z_FS
Old Aug 13, 2007 | 04:35 PM
Zridder19's Avatar
Zridder19
I have 650cc injectors, and no fuel return. Everything is fine, no problems.
I hope this helps:
https://my350z.com/forum/showthread....rmance+Factory
Old Aug 13, 2007 | 05:39 PM
VIZAGE's Avatar
VIZAGE
I have 550cc injectors and no return system. No problems at all.
A good tuner will tell you what needs to be done. Some cases you can get by, others you can not. All depends on several factors.
Old Aug 13, 2007 | 05:46 PM
Nexx's Avatar
Nexx
+1
Old Aug 13, 2007 | 05:50 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
i have 20 cars running around with that same setup, mostly all stock motors...
we are about to push AJs car a little bit to see how the stock system holds up.
Old Aug 13, 2007 | 05:52 PM
TurboTim's Avatar
TurboTim
Vendor - Former Vendor
No return on my ride either.479WHP on stock motor and no problems for 28,000 twin-turboed miles
Old Aug 13, 2007 | 06:27 PM
moog's Avatar
moog
Should I just drop the Walbro in, or do I have to mod it?
Old Aug 13, 2007 | 06:29 PM
Zridder19's Avatar
Zridder19
are you F/I??
Old Aug 13, 2007 | 06:30 PM
moog's Avatar
moog
I have Vortech w/ newly installed 3.12 pulley, 440 injectors...fuel pump going in this week along w/ test pipes. Hope to get it tuned by this Saturday.
Old Aug 13, 2007 | 06:31 PM
Zridder19's Avatar
Zridder19
I would definatly get it tuned when you put it in
Old Aug 13, 2007 | 06:36 PM
moog's Avatar
moog
Yeah ever since putting in the 440's its been running super rich.
Old Aug 14, 2007 | 04:25 AM
jpc350z's Avatar
jpc350z
I have 440 + Walbro , no return and about 80psi fuel pressure at idle and slightly lower at driving .. At WOT the FMU and Aux fuel pump kick in and fuel pressure rises to around 95/100 psi.. Its tuned and runs well..
I would look into the Walbro mod's Tn recommends as well as Phunks mod to the swirl jet to bring the Fuel press down to around 50psi idle..Not sure what long term ill affects running a high fuel pressure might be...
Old Aug 14, 2007 | 06:10 AM
Dynosty's Avatar
Dynosty
One reason not to run real high fuel pressure with a walbro is flow. The flow falls off drastically with high fp.
Approximate flow from Walbro 255:
@50psi supports ~650bhp
@70psi ~588bhp
@90psi ~444bhp
@100psi ~325bhp
@110psi ~156bhp
Old Aug 14, 2007 | 08:29 AM
Triple8Sol's Avatar
Triple8Sol
With my Stillen kit, I was running a Walbro 255 and just the regular RC750 7th injector. With the Vortech, I'm running the 3.12 pulley, Walbro 255, and RC 440's. I'll let you know how it goes when I get down to fine tuning it...
Old Aug 14, 2007 | 08:48 AM
Quamen's Avatar
Quamen
I have been running a walbro pump w/o a return line on a stock motor for a year now with no problems. I believe I am a bit rich but nothing to drastic.
Old Aug 14, 2007 | 09:25 PM
moog's Avatar
moog
So you're running a Walbro 255 along with the Vortech FMU and auxiliary 155lph fuel pump?
Old Aug 15, 2007 | 04:14 AM
jpc350z's Avatar
jpc350z
Yes.. and RC 440 cc inj's..
Old Aug 15, 2007 | 05:08 AM
04treefiddy's Avatar
04treefiddy
I have the walbro 255 and no return fuel system.. Fixing to add some injectors.
JPC no need to run that aux. pump with the vortech if you are running the 440's, walbro and fmu.
Old Aug 15, 2007 | 06:04 AM
jpc350z's Avatar
jpc350z
I am sure you are correct but I have it tuned with this set up and would have to get it retuned w/o the FMU/Aux fuel pump....No return system. How is your A/F ? A dyno chart would be great..Do you have a fuel pressure gauge and what pressure do you see at idle and WOT?
Thanks
