Turbonetics Reflash/Utec/Emanage
Old Sep 21, 2007 | 04:16 PM
diwun67's Avatar
diwun67
Originally Posted by taurran
The problem never really made sense to me. I'd have to dig up the post to even remember the full discussion.
overboost in 1st and 2nd gear, jittery in every other gear
Old Sep 21, 2007 | 08:19 PM
TayTaythatsme04's Avatar
TayTaythatsme04
Originally Posted by GQ 350z
Ok, excellent. But UTEC has everything I need (sensors or whatever)?
Yes like someone said above you will at least need a map sensor. I also added the tuner to the Utec but thats not needed.
If I'm not overboosting I understand I wont need the WG spring?
If you not over boosting then great. I was so I had to change a few things to get them the way I wanted, safe.
I intend on a few gauges as well, but not sure which ones are necessary. I've posted many time about the turbonetics but its hard to find my old posts with so many different types of info.
My purchase is kind of in the works right now, and its happening very fast so I'm scurrying ot get everythign I need. Would $1500 be fair for install/tune for turbo + utec? Or am I being unrealistic?
Depends on where you go. IN saying that where were you planning on taking it?
Old Nov 4, 2007 | 10:19 PM
bbs350z's Avatar
bbs350z
is anything over 400rwhp on a basic reflash possible? 440cc inj's btw.
Old Nov 5, 2007 | 02:58 PM
diwun67's Avatar
diwun67
You'd have to have the ecu reflashed for the 440cc injectors
Old Nov 5, 2007 | 03:00 PM
taurran's Avatar
taurran
+1.... and this thread is old!
Old Nov 5, 2007 | 03:59 PM
freezeg35's Avatar
freezeg35
I just happened to buy a utec today, and will drive to gtm in april to get it installed and tuned. Should i leave the stock 380s in and tune or upgrade to the aps 440s that gtm suggested, or maybe 550s?. George also said i would most likely need a fuel pressure booster as well, not to sure what that is.
TIA.
Old Nov 5, 2007 | 04:00 PM
taurran's Avatar
taurran
Originally Posted by freezeg35
I just happened to buy a utec today, and will drive to gtm in april to get it installed and tuned. Should i leave the stock 380s in and tune or upgrade to the aps 440s that gtm suggested. George also said i would most likely need a fuel pressure booster as well, not to sure what that is.
TIA.
Forget 440's, waste of money IMO. Skip up to the 550's.
Old Nov 13, 2007 | 11:19 AM
hr2burn's Avatar
hr2burn
I came across this thread. Did original poster ever get the UTEC? I had no problems with the TN reflash...builtproof! But add a UTEC to a reflashed ECU and PROBLEMS. Curious where this setup is.
P.S. Reflashed stock ECU back to stock parameters and all is great.
Old Nov 13, 2007 | 12:31 PM
bbs350z's Avatar
bbs350z
would it be safe to drive the z with the tn kit (no reflash) about 100 miles to get a utec and tune?
my friend might buy my tn kit and wants to know if itll be safe to drive
Old Nov 13, 2007 | 02:08 PM
diwun67's Avatar
diwun67
You may wanna specify what you mean by "problems" because I have none as far as engine management goes with the TN reflash and UTEC combo.
Old Nov 13, 2007 | 02:59 PM
taurran's Avatar
taurran
Same here.
Old Nov 13, 2007 | 05:46 PM
hr2burn's Avatar
hr2burn
Wow...that's interesting. Like I said I never had a bit of issue with the TN reflash, everything was spot on. When I wanted to up the power so I put in the UTEC, I had tons of stutters. If I transistioned from the ECU to the UTEC slowly/ smoothly not normally any problems. But when racing (1/4 mile) it was a mess. I fought with it for 6 months or more. I came across a Ttuner that said I had the 2 fighting each other. He gave logical reasoning enough that I (terrified) had a stock reflash.
Problems gone. I know people with non reflashes and F.I. with no issues and of course the same of NA with UTEC and no issues. Myself and a friend who has a reflash, utec and twin turbo's has the same issues I did. I am sure it's an issues, have no idea why it doesn't effect you guys. The 1st tuner I had trying to fix is a tuner recommended my Turbo XS so it was not the tuner. The 2nd tuner just has come accross this problem before. I really am not looking for a debate just wish I had someone able to tell me months ago... sorry for the hi-jack.
Old Nov 13, 2007 | 06:04 PM
taurran's Avatar
taurran
I dont see how the two could be "fighting each other" as he put it, as it functions exactly the same as the stock ECU. Oh well.
Old Nov 13, 2007 | 06:28 PM
hr2burn's Avatar
hr2burn
The stock ECU is looking for and adjusting for boost...now you have 2. Just keep it in mind if you have strange issues. Keep in mind I am COMPLETELY happy now!
Old Nov 13, 2007 | 07:09 PM
diwun67's Avatar
diwun67
+1
Old Nov 14, 2007 | 04:15 AM
taurran's Avatar
taurran
No it doesn't. The factory ECU is totally blind to boost. All the stock ECU does is adjust the fuel mixture and timing based on RPM/AFR/fuel/knock.
Old Nov 14, 2007 | 06:05 AM
hr2burn's Avatar
hr2burn
I'll ask him to give me an explanation in an email. I am not a tuner, but I know what fixed my nightmare- a reflash. There was obviously nothing wrong with my TN reflash...It was GREAT! The UTEC seemed so the problem I had it replaced after the 1st tune attempt. Nothing changed. I may have even burned a bridge with a great tuner here local because he was unable to fix problem even though he could data log it. Anyway when I see someone writing something similar problem to mine, I will share my experiance. That is not this situation with this thread....sorry.
Old Nov 14, 2007 | 08:28 AM
  #38
taurran's Avatar
taurran
This thread is pretty much done anyway. I'm not saying it's impossible for it to be the source of the issue. Reports of it just seem to be random at best.
dynamic6er
Jul 22, 2005 07:31 PM
MIAPLAYA
Jul 8, 2005 05:52 AM
Sharif@Forged
Jul 7, 2005 05:38 AM
MIAPLAYA
May 9, 2005 07:51 AM
