Vortech with a 2.62 pulley
Old Sep 11, 2007 | 12:15 PM
Jay'Z's Avatar
Jay'Z
Old Sep 11, 2007 | 07:50 PM
jtgli's Avatar
jtgli
BTW sentry to answer your question yes this is going to be on a built motor. Its my brothers car. Its a stage 1 short block and the oem heads. 9.1:0 compression....
Old Sep 12, 2007 | 01:09 AM
04treefiddy's Avatar
04treefiddy
The 2.62 will only fit if you mill the lip off of the jackshaft area... or Space it out a 1/4 of an inch.(which i did). i'm working on my setup now to help with the rest of the supporting mods i need now. The belt has not slipped.
Old Sep 12, 2007 | 12:47 PM
ImportPartsPro's Avatar
ImportPartsPro
Vendor - Former Vendor
I am doing a setup with a machined 2.62 pulley right now. What size belt are you guys using?? And is it on a standard setup or with and second adler like GTM has done?
Old Sep 12, 2007 | 05:35 PM
04treefiddy
mine is on the stock idlers and cog pulley.. I used a k060926 from gates... it could stand to be alittle longer though.
Old Sep 12, 2007 | 07:08 PM
Mr_pharmD's Avatar
Mr_pharmD
Originally Posted by 04treefiddy
mine is on the stock idlers and cog pulley.. I used a k060926 from gates... it go stand to be alittle longer though.
do u have pix of your setup? what does the cog pulley look like and are u using a spacer or did u mill the jackshaft?
Old Sep 13, 2007 | 01:04 AM
04treefiddy
I used a spacer and the belt is still almost straight. So there is no issues there. I will take some picks of it this weekend for you. Car is down right now anyways, due to me fixing to put a clutch in it.
350Z_Al
Oct 29, 2020 07:44 PM
Fixxxercask
Nov 9, 2015 11:10 AM
seagrasser
Oct 11, 2015 03:27 PM
Calinismo350z
Sep 14, 2015 04:04 PM
