Vortech with a 2.62 pulley
Old Sep 7, 2007 | 11:46 AM
Floridaboy1605's Avatar
Floridaboy1605
Default Vortech with a 2.62 pulley
Hey does anyone run a vortech with a 2.62 if you do what are you supporting mods and what kind of power should i be expecting thanks for the help guys.
Old Sep 7, 2007 | 01:07 PM
booger's Avatar
booger
If you had a 2.62 pulley , it would more than likely need to be milled to fit around the jackshaft when installed . I had a 2.87 that wasnt milled to fit on a jackshaft
Old Sep 7, 2007 | 03:03 PM
Jay'Z's Avatar
Jay'Z
What psi is a 2.62 supposed to put out?
Old Sep 7, 2007 | 03:05 PM
Nexx's Avatar
Nexx
lol
Old Sep 7, 2007 | 03:09 PM
booger's Avatar
booger
I dont believe any one has ran it Jay .
IMPO...I dont think it would even fit on the jackshaft with out rubbing on it . It would be about the same diameter as the jackshaft..or close .
Old Sep 7, 2007 | 03:11 PM
Jay'Z's Avatar
Jay'Z
Originally Posted by Nexx
lol
WTF is so funny?? I dont have a Vortech.. So...... Being you put that dumb **** in your sig "3.12" that has to mean it controls boost.. Nexx sometimes your just so annoying.. (your sig your looking for Evo TT) BTW EvoTT's have been in stock at Forged Performance at all times.. I dont see what the **** your waiting for???
Old Sep 7, 2007 | 03:12 PM
Jay'Z's Avatar
Jay'Z
Ok, Thanks booger.. Thats the type of response I was wanting..
Old Sep 7, 2007 | 03:21 PM
booger's Avatar
booger
https://my350z.com/forum/showthread....ht=2.87+pulley
Here is the thread where I posted about the 2.87 not fitting and the damage it did to my jackshaft . I later milled the pulley to fit on it......but didnt ever use it...went to the T-trim blower instead .
Old Sep 7, 2007 | 03:26 PM
booger's Avatar
booger
vortech 2.87 pulley not right-boogpull6.jpg.
Here is the actual damage done to the jackshaft edges . I put the pulley on and tightened it down with out checking to see if it spun freely.....I know...stupid of me !!!
Old Sep 7, 2007 | 03:32 PM
sentry65's Avatar
sentry65
the burninator
is this setup for a stock or built engine? I'd actually start to consider an intercooler upgrade with the blower working that hard. IMO I'd leave the stock diameter piping though.
I'd rather run a 34 tooth cog pulley on the rear of the jackshaft with the 2.87 pulley than run the 2.62 pulley by itself. Belt slipping will be minimized with the 34 toothed and 2.87 pulleys compared to using a smaller 2.62 pulley
I wouldn't rev above 6700 rpms either with that setup. Or likewise if you ran the 2.87 pulley by itself, I wouldn't rev past about 7100 rpms
I think Kevinapex was running the 2.62 pulley on a built engine before switching to the SFR TT kit. He was making pretty good power too with his setup. His sig said 480 whp at the time if I remember right
GTM sells both the 34 tooth cog pulley and larger intercooler designed to work with the vortech
Old Sep 7, 2007 | 03:45 PM
Nexx's Avatar
Nexx
WTF is so funny?? I dont have a Vortech.. So...... Being you put that dumb **** in your sig (3.12) that has to mean it controls boost.. Nexx sometimes your just so annoying.. (your sig your looking for Evo TT) BTW EvoTT's have been in stock at Forged Performance at all times.. I dont see what the **** your waiting for???
i was lol'ing because all of the ordeal that you have gone through with your procharger and trying to get all the boost out of it. for some reason i knew you would be the first person to ask. i thought it was funny. i wasnt laughing at you Jay. my evo tt is sitting at home in a nice box, im just lazy and havent fixed it. sorry to get you so upset. i'll use a smiley next time so that you know im just ribbin ya.
Old Sep 7, 2007 | 03:48 PM
Jay'Z's Avatar
Jay'Z
Oh, I have been going through more than just the procharger.. If you check the LSD thread I made.. Just spent 4k on a damn diff .. My bad.. I went off cause my blood pressure is still high from that bill.. Its all good you ribbed me.. Just dont be lazy..
Old Sep 7, 2007 | 03:57 PM
Nexx's Avatar
Nexx
oh my, damn, sorry to hear that bro. i hope that everything turns as you want it this time. for 4k it better.
Old Sep 7, 2007 | 04:24 PM
booger's Avatar
booger
If some one got a 2.62 pulley to work . I would love to see a close up pic of it !
Long before Vortech came out with a 34 tooth cog pulley to work on the jackshaft . I had one custom made from a 50mm wide pulley used on a Vette kit . I used it with the 3.12 pulley to equal a 2.87 . If your thinking of using the 2.87...I would go this route instead....more pulley suface to help the serp belt grab better. And the better it grabs....you will not have to have the serp belt so tight...and that will help the bearings in all the pulleys last longer . Including your power steering and alt. pulleys .
If you are interested in upgrading your intercooler , Pm me , I can suggest a very good bar & plate design IC that is far cheaper than what others would use and charge you for it . We are way over charged for most of our mods any way...so finding cheaper....but just as good....mods...is always good .
As far as over reving the blower....lets just say you are never in the 6500 to 7100rpm range long . And it isnt going to hurt the blower or make that much of a difference in the efficiency of the blower in that few rpm's
Old Sep 11, 2007 | 08:19 AM
FranksBAG's Avatar
FranksBAG
I have a 2.87 and 2.66 both milled with a larger crank pulley from fluid dampner. also have external wastegate to control boost. works fine
Old Sep 11, 2007 | 08:29 AM
jpc350z's Avatar
jpc350z
Can you elaborate more on your set up with the wastegate..Where is it located and what is your overall set up and power / Tq #'s..Thanks
Old Sep 11, 2007 | 09:00 AM
FranksBAG's Avatar
FranksBAG
i have a tial 44mm wastegate after the vortech bov. with the smaller pulley and stock internals i can run higher boost with no added worries about blowing my engine. also have a boost controller. tQ#'s are a little higher
Old Sep 11, 2007 | 09:41 AM
jpc350z's Avatar
jpc350z
What are the tq #'s?
Old Sep 11, 2007 | 10:45 AM
Blackbird CPV35's Avatar
Blackbird CPV35
i was always wondering if a wastegate setup would work well with a centrifugal SC, can you post pics please?
Old Sep 11, 2007 | 11:54 AM
booger's Avatar
booger
Some one has already done the wastegate with elec. boost controler . He said it worked well .
I would just love to see a close up pic of a 2.62 pulley on the jackshaft . I just have a hard time believing it will fit over the part of the jackshaft that sticks out of the bracket .
