Vortech Dyno Number a little low?
Old Sep 8, 2007 | 01:02 PM
booger's Avatar
booger
Originally Posted by Triji
I was reading this post by booger:
https://my350z.com/forum/forced-induction/85752-vortech-2-87-pulley-not-right.html
Here is a pic he posted of what happened when he installed the 2.87.
https://my350z.com/forum/attachment....7&d=1091575043
https://my350z.com/forum/attachment....9&d=1091410849
https://my350z.com/forum/attachment....6&d=1091408813
I just don't want to have these same issues as Booger did...
If you notice the date on that thread Triji .....it was old !! I believe Vortech corrected the pulley after that happened. I just wanted to show what happened to compare what MIGHT happen with a 2.62 . As I stated....I dont think the 2.62 will work...at least with out modding it any way .
Old Sep 8, 2007 | 01:12 PM
Triji's Avatar
Triji
Ok, Cool.... I am going to place it on there today as I am putting on my new GTM idler pulley while I have my belt off and see how it fits... Cant put the 2.87 on tho until I get my Utec / Inj's / Walbro in...
I am hitting 8.5 psi w/ the 3.12 now... I am interested to see if the PSI increases a bit with the new GTM idler pulley installed.
Old Sep 8, 2007 | 01:33 PM
booger's Avatar
booger
Ok, I hope you dont mind, I played a bit... where I circled is where I think you can gain more power... I would tend to think slippage here....
I colored in where your power and TQ looks like where it should go... Kinda like my NVDA stock
Triji
His whp and trq. leveling off may have come from timing being pulled and or fuel being added . And not belt slipping . I think he said he only had 14.5 degree's of total timing at redline
Old Sep 8, 2007 | 02:12 PM
Blackbird CPV35's Avatar
Blackbird CPV35
Triji
thats why i want to know what similar setups are running timing wise, i wasnt sure if that was low or high
Old Sep 8, 2007 | 02:22 PM
04treefiddy's Avatar
04treefiddy
The 2.62 rubs the s/c bracket. I had to space it out 1/4 of a inch rather than mill on the pulley or bracket. It's working fine. The belt is lined up great. No problems with it even at 6500rpms.
Old Sep 8, 2007 | 02:32 PM
booger's Avatar
booger
What year is your car ? On mine [ 03 ] the jackshaft sticks out away ffrom the main bracket . And when I put on the unmilled 2.87 , it tore up the edges of the jackshaft as shown in this pic
https://my350z.com/forum/attachme...7&d=1091575043
What your saying is the the 2.62 hits the main bracket and not the jackshaft . Can you take a close up pic of it ?
Old Sep 8, 2007 | 02:37 PM
booger's Avatar
booger
I would be careful adding back in the timing ! Might want to take it to a pro tuner to make sure . Looks like you have it real close on the tune and it shouldnt take a tuner long at all to finish it to get the most out of it .
Old Sep 8, 2007 | 03:16 PM
04treefiddy
Yeah the lip on the bracket is what the 2.62 hits.
Old Sep 8, 2007 | 03:41 PM
booger's Avatar
booger
Im thinking you mean the jackshaft . It [ the jackshaft ] sticks threw the main bracket like in the pic . Still would be nice to see a close up of it though
Old Sep 8, 2007 | 04:05 PM
DMK's Avatar
DMK
How safe is that with a overdriven sc? Because with a 2.62 pulley, the blower is spinning at 59,000 @ 6500 rpm. And the max recommended impeller speed for a V2 SC-Trim blower is 53,000 rpm.
Old Sep 8, 2007 | 04:14 PM
booger's Avatar
booger
How much time is being spent above 6000rpm's ? I dont think over spinning a blower is as bad as some make it .
Old Sep 8, 2007 | 04:17 PM
DMK's Avatar
DMK
Well what if you were on a long track doing 30 min sessions. Would it hurt it in any way? What do you think the limit should be...up to 63k safe?
Old Sep 8, 2007 | 04:24 PM
booger's Avatar
booger
Well thats a whole different story and I wouldnt know the answer . Most guys with a SC arent at the track and there are a hundred other factors to consider before saying something is safe or not .
My point was as I stated...MOST of us dont spend much time above 6000rpm with a SC and over spinning the blower isnt going to hurt it .
Old Sep 8, 2007 | 05:25 PM
sentry65's Avatar
sentry65
the burninator
what about overdriving your $7000 engine with more power??
Old Sep 8, 2007 | 06:45 PM
booger's Avatar
booger
my motor only cost $3900.00 by the way ! ooops forgot the cams..$5100.00
Old Sep 8, 2007 | 06:48 PM
sentry65's Avatar
sentry65
the burninator
I meant a brand new OEM motor, not what any of us have paid for a built bottom end or cams. Of course no one would buy an OEM brand new engine, but still, all this worry about the blower when the engine itself is the thing people should be more worried about with the labor involved with pulling the engine out etc
Old Sep 11, 2007 | 08:12 AM
FranksBAG's Avatar
FranksBAG
just add a wastegate to your setup i did
Old Sep 11, 2007 | 08:14 AM
  #38
FranksBAG's Avatar
FranksBAG
also any pulley under the 3.12 has to be milled so it doesnt hit inside jackshaft and bracket.
Old Sep 12, 2007 | 04:38 PM
  #39
Hexxum001's Avatar
Hexxum001
blackbird-I am also running the 2.87 pulley on a similar setup as yours minus the fuel return, test pipes and spacer. I am at 384whp on a pretty conservative tune. This weekend I am switching from from my HKS Hi Power exhaust to GReddy Evo TT and also installing some Fast Intentions HFC's. Hopefully this will get me pretty close to 400whp. That's a pretty decent number bro.
Old Sep 13, 2007 | 11:41 AM
  #40
nismomonster06's Avatar
nismomonster06
so has it been concluded that any pulley under the 312 has to be machined to fit properly without having to worry about problems or did i hear that vortech fixed that problem... can we get someone from vortech to chime in maybe (steve) or other people that may know...
