Vortech Dyno Number a little low?
Old Sep 7, 2007 | 07:02 PM
Blackbird CPV35's Avatar
Blackbird CPV35
Default Vortech Dyno Number a little low?
Stock Block
Vortech w/ 2.87 pulley
CJM stage 1 FR
Utec
660cc injectors
Borla Exhaust
Test Pipes
MD 3/8" plenum spacer
I started with a basline of 361 whp then got up to 400, this was on a dynojet so it seemed pretty low for the mods, I had the AF perfect at ~11.4:1. I stopped because I thought that my timing was getting awfully high (I was at 14.5 at the 100% load site at redline) I was experienceing absolutely no knock on 93 octane.
any advice? do you think I still have room for more timing advance, most people with the 2.87 are putting up alot higher numbers than that on a DJ
Old Sep 7, 2007 | 07:05 PM
Nexx's Avatar
Nexx
not sure what what numbers you are seeing but 400whp is about right with your mods and a 2.87 pulley. im getting around 370whp with my 3.12. i expect to hit about 400whp with a 2.87 pulley.
Old Sep 7, 2007 | 07:09 PM
Triji's Avatar
Triji
looks like you are getting a bit of a belt slip at 6200 rpms to redline...
Old Sep 7, 2007 | 07:12 PM
Blackbird CPV35
i got the timrod fix and have the tensioner on pretttty tight, looks like i have to tighten it more.
what kind of timing are you guys running at max boost and redline?
Old Sep 7, 2007 | 07:27 PM
Triji's Avatar
Triji
I am still using the SS box and 3.12 pulley... I have no clue on my timing actually although I know it is fairly aggressive as I am running a mix of 91 and 101 oct gas.
I hit 380 rwhp on a dyno dynamics dyno which reads a bit low compared to a dynojet...
Looking at your plot from 6200 up it stays flat with a downward tendancy, this is where I think you might be slipping a bit.
I just got the GTM extra idler pulley and am going to install it tomorrow.
Old Sep 7, 2007 | 07:31 PM
Mr_pharmD's Avatar
Mr_pharmD
not sure if i got this right. U were on the 3.12 pulley before and on this dyno it was around 340 but once u put the 2.87 pulley on it jumped to 400? Is that correct? If so, that's 60hp increase so what are u complaining about? On average, ppl get only 30 hp increase from 3.12 pulley to 2.87. I would like to see what psi you are at and if it's slipping bc the timrod method is suppose to stop slippage.
Old Sep 7, 2007 | 07:55 PM
Triji's Avatar
Triji
Ok, I hope you dont mind, I played a bit... where I circled is where I think you can gain more power... I would tend to think slippage here....
I colored in where your power and TQ looks like where it should go... Kinda like my NVDA stock
Old Sep 7, 2007 | 10:16 PM
Blackbird CPV35
no this is all 2.87, I went from 360 to 400 just messing with the timing
im hitting about 11.5 psi, not sure what the 2.87 is supposed to top out at
Old Sep 7, 2007 | 10:27 PM
Triji's Avatar
Triji
Is this on a 5AT or a 6MT?
was the 360 "before" tuned at all? As I said I am hitting 380 on a dyno dynamics on a 3.12 at 8.5psi and I am a 5AT... This on stock injectors and the SS box...
My main mods are in my sig....
I have RC 650's and a Utec waiting to go in as well as a Walbro... I am going to run the stock fuel rails.
11.5 sounds about right as far as your PSI... thats 3 more PSI than my 3.12 is giving me.
Once I get my 2.87 and Utec in I will let you know what I get out of it.
P.S. did you have to mill your 2.87 to get it to fit? Or did it just go on without any modification?
thanks.
Old Sep 7, 2007 | 10:33 PM
Nexx's Avatar
Nexx
11.5 psi is damn good. no belt issues there. i just think you were expecting too much from your vortech setup. dont mind the dyno queens who claim 400whp with 3.12's, thats just not realistic. if you really want mid 400's then go with a cam upgrade.
Old Sep 7, 2007 | 10:58 PM
sentry65's Avatar
sentry65
the burninator
add cams and headers if you want more power - and/or a 34 tooth cog pulley
Old Sep 7, 2007 | 11:22 PM
cwestrx7's Avatar
cwestrx7
man thats exactly what i am hoping to make. thanks for posting your sheet.
Old Sep 7, 2007 | 11:49 PM
Nexx's Avatar
Nexx
sentry, you really think headers are worth it? cost of installation just turns me off on them.
Old Sep 7, 2007 | 11:55 PM
Mr_pharmD's Avatar
Mr_pharmD
mill down to fit 2.87??? It fits like every other pulley. Headers and cams make a big difference. With the 2.87 pulley i was making 430hp on my AT on DD dyno.
Old Sep 8, 2007 | 12:07 AM
sentry65's Avatar
sentry65
the burninator
i can't say if any mod is worth the money or not, but headers and cams will add more power - so will water/meth injection, higher octane gas, and more timing
Old Sep 8, 2007 | 04:39 AM
booger's Avatar
booger
Stock Block
CJM stage 1 FR
Utec
660cc injectors
Borla Exhaust
Test Pipes
Great numbers !!! dont push the timing to much !
Old Sep 8, 2007 | 06:05 AM
04treefiddy's Avatar
04treefiddy
Nexx... Dyno queen huh? I made 395/325 with the 3.12 pulley, aam spacer, test pipes, full exhaust and a walbro. I ran 12.2@115 with that setup. So no dyno queen there bud.
Old Sep 8, 2007 | 09:07 AM
Blackbird CPV35
i wouldnt be complaining if this was 400 hp on a dyno dynamics, but this was on a dynojet sae corrected with the smoothness on 5
and to answer the pulley question, no i didnt have to mill it it just needed to press it onto the jackshaft
Old Sep 8, 2007 | 10:36 AM
Triji's Avatar
Triji
I was reading this post by booger:
https://my350z.com/forum/forced-induction/85752-vortech-2-87-pulley-not-right.html
Here is a pic he posted of what happened when he installed the 2.87.
I just don't want to have these same issues as Booger did...
Old Sep 8, 2007 | 11:25 AM
Blackbird CPV35
https://my350z.com/forum/showthread.php?t=85752
that might have been a freak incident, I ordered mine from summit racing and it worked fine
