Couple Pics of My Turbonetics 350z
Originally Posted by Tekwon-V
you have the boost/vacuum port hooked up wrong on your Raptor BOV. use the upper port por favor.
looks good though!
looks good though!
huh what do u mean, estoy lost
thanks
thanks
thanks
That is the correct connection for the Boost Signal to the Raptor BOV. Good catch Tekwon
if you look at the Raptor, you will notice there are 2 threaded holes - one on the cap (furthest away from the mounting flange) and one "in the middle" (closer to the flange).
from your picture, it looks like you have it connected to the one closer to the flange.
got ya, changing it now, whats the difference?
Originally Posted by MIAPLAYA
With the line hooked to the wrong fitting the BOV may not remain closed during full boost pressure and might also possibly not open fully during shifts to properlly release boost pressure.
you can use the bottom port as a boost-sensing hook up. this could help the valve open up quicker (vacuum pulling up and boost pushing up) but it is generally not needed/used.
your setup looks nice. what kind of exhaust are you running?
Thanks, running Full 3in turbo back to a HKS Ti Carbon Fiber Canister
http://www.hksusa.com/products/?id=1733
ok, I corrected the connection on the bov and test drove it this morning and I believe car feels more powerful. however the roads a wet so I don't know if it was losing traction but I noticed it overboosted to like 14 lbs..... what's ur take on this? also I the bov sound way different now. it sounds like a solid psssh instead of a psst pssst pssst pssst (fluttering release)..
