TQ converter in depth
Old Sep 21, 2007 | 02:21 PM
rcdash's Avatar
rcdash
^ ha ha
coachk is right - no further explanation is necessary. A 3500 stall will mean you can move further into the rpm band before the car will lurch forward as you describe. Obviously your engine will be in a better position to provide better torque output at that rpm...
Originally Posted by marques1
how the hell would my brakes hold a stall of 3500 rpms i guess i was not pushing down hard enough on my brakes or something?
No he was talking about getting an upgraded tc set to a 3500 stall.
The higher stall upgrade will allow the tc to slip...
Old Sep 21, 2007 | 02:37 PM
marques1's Avatar
marques1
ok i understand now thank you very much
Old Sep 21, 2007 | 08:33 PM
Jtrain's Avatar
Jtrain
So the TC is the reason when I'm driving my Jeep SRT8 I have to dig into the gas a little bit before it actually goes anywhere? is that the feeling of a 3000rpm+ stall?
Old Sep 22, 2007 | 08:25 AM
helldorado's Avatar
helldorado
It could be a factor of tuning, I'm pretty sure those are drive by wire. IIRC reading an article about them, a ECU reflash does a lot to improve throttle response, so its not necessarily a function of the TC. Very few street cars from the factory, if any, have stall speeds over 3000 rpm, it affects drivability at low engine rpms, making the car feel sluggish and can lurch.
Old Sep 22, 2007 | 08:39 AM
helldorado's Avatar
helldorado
Some more reading from EDGE Racing's website.
What is Torque Converter Stall?
The easy answer is: The RPM a torque converter will allow the engine to attain with a given engine torque input.
How is Torque Converter Stall Measured?
That's where the confusion begins between the racer and the high-performance torque converter builder. Stall is measured in three different ways. TRUE, BRAKE and FLASH Stall. The only true way to set stall is using TRUE stall math.
What is TRUE Stall?
True stall is measured with the transmission locked (Trans brake) and the drive shaft still. The throttle is then fully depressed and held to obtain the holding RPM of the torque converter. This is the "TRUE" Stall.
What is Foot Brake Stall?
This is attained with the transmission in gear and the brakes depressed fully. Now slowly apply the accelerator. The RPM the engine reaches the moment before the tires spin is known as the "BRAKE" Stall. BRAKE Stall is not a consistent way to measure your stall converter and has many variables. This method will be lower then TRUE stall by 400-800 RPM.
What is FLASH Stall?
Flash stall is generally read while the car is in motion. While rolling at a slow speed the throttle is depressed fully to see where the RPM will flash (or peak). This method will not be true if tires spin or car is rolling too fast. Due to the turbine already turning in the torque converter we end up with less torque multiplication. This will give you a lower stall reading of between 200 and 600 RPM under the converters TRUE stall in the same application.
norrix420
350Z Roadster
May 23, 2022 05:11 PM
sales@czp
Sep 23, 2019 03:30 PM
ejv8s10
350Z Roadster
33
Jun 14, 2016 08:31 PM
Fixxxercask
Interior
Oct 6, 2015 10:17 AM
