Fuel Supply Connector Popping Out
Old Sep 21, 2007 | 06:00 AM
eez's Avatar
eez
Default Fuel Supply Connector Popping Out
I'm gonna call Vortech this morning, but wanted to get some input from people more experienced than me . My input supply line (from the tank) to the FMU has popped out twice spewing gas all over. The 1st time it happened I thought I didn't have the connector pushed in all the way. So I reconnected it and now, about a month later it popped out while trying to start.
I used the OEM clip that was used to make the stock connection on the FMU output side so it is nice and tight and no way it's coming off. But the input side didn't come with a clip, just a metal female connector. BTW I tried to use the clip on the input side but it wouldn't fit.
Any thoughts on how to resolve this??? I was thinking I could band aid it with electrical tape, but not sure if thats a good idea or if it will hold in the long run.
Old Sep 21, 2007 | 08:17 AM
eez's Avatar
eez
wow vortech was a lot of help. they told me they never heard of that happening before on any of their kits... and that was about it
Old Sep 21, 2007 | 09:09 AM
Sean's Avatar
Sean
That may be true, but I know for a fact that some other companies instruct customer service, sales and tech reps to claim they never heard of issues before and it must be "an anomoly" with that one particular user.
Old Sep 21, 2007 | 09:28 AM
jpc350z's Avatar
jpc350z
I had the same problem apprx 5k miles after install..Can't help with the fix because I took it back to the shop that installed it but so far it's held up another 5k miles..
Old Sep 21, 2007 | 09:35 AM
eez's Avatar
eez
thanks. i'll probably ask for a new female connector from vortech.
Old Sep 21, 2007 | 04:33 PM
fklentz's Avatar
fklentz
I'm supposing that you're talking about the connection where the fuel line plugs into the plastic stub on the outside of the fuel tank. Mine popped off a few hundred miles after VRT worked on it. What I found was if i pushed it on until I heard a "Click" and then pulled on it that would pop off with a little effort. I then pushed it on again to the click and them held it with a rag and pushed it a little further on until I heard another "pair" of clicks. I then tugged on it until I was sure it was on securly and have not had one problem in over 6K miles.
Old Sep 24, 2007 | 07:33 AM
eez's Avatar
eez
well I made a mistake I got under there it was the connection from the FMU to the block, not from the tank to the FMU. The connection is a metal male connector to the stock female connector. I do not hear or feel a click and I pushed it in as far as it would go, it was then fairly easy to pull the connection out. I ended up using zip ties on each end and zip tied them to the tank connection and I am certain it's not coming out again
Old Sep 29, 2007 | 10:21 AM
zzerotwosixty's Avatar
zzerotwosixty
I had the same problem during my install. Zip ties FTW.
sales@czp
Sep 23, 2019 03:30 PM
Tochigi_236
Sep 27, 2015 03:40 PM
