utec
Old Sep 22, 2007 | 06:58 PM
kevin8086's Avatar
kevin8086
Default utec
theres a little grey round switch with a v notch in it and when you turn it you can see different numbers, i think 0-9 or 1-9 not to sure well if you turn this in circles to different numbers what is it doing. this is on the outside of the utec on the bottom i think, thanks
Old Sep 22, 2007 | 07:00 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
lol, read the manual yet? its the map selector. go read the manual to see what all you can do with that ****, how it interfaces with the remote map selector and how it controls your maps.
Old Sep 22, 2007 | 07:03 PM
kevin8086's Avatar
kevin8086
uh oh, so if i turned it to a different number and dont know where it was to begin with thennnnn........ i guess i need to hook it up to my laptop and find the map that i just had tuned??
Old Sep 22, 2007 | 07:06 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
yep.
if you had good tuner, he would place the map in all the slots. Id suggest you do that if the tuner didnt. Its just a precautionary method.
so you read the manual on how to connect to the utec (which isnt hard, but its not a 2 step deal) but you missed the part about map selection?
Old Sep 22, 2007 | 07:10 PM
kevin8086's Avatar
kevin8086
oh no, i bought the car already done, had turbos and utec, but i just recently had it tuned at GTM because the utec was tuned for 93 and here i only have 91. but i know it's not loaded in all the different locations because when i turned the *** the car started shaking and almost wanting to stall so i turned it until it stopped shaking.( which is on positions 1,2,3 but all the rest make the car shake)
Old Sep 23, 2007 | 08:18 AM
kevin8086's Avatar
kevin8086
so if i have my laptop hooked up to the utec and i turn that switch will it show me each tune as i turn the selecor
Old Sep 23, 2007 | 08:26 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
leave the swtich alone! Once you connect to the utec, you can see every map. go to the turboxs site and download the manual and read it. The interface isnt complex, but its not straight forward.
First thing i would do, is to save a copy of every map to your computer!
Old Sep 23, 2007 | 09:55 AM
kevin8086's Avatar
kevin8086
yeah i read the manual, but my stupid windows vista laptop doesnt have hyper terminal and it also has a female connection for the serial cable just like the utec so i need a double male to make it work. man i wish GTM would have told me there were different maps on here and maybe give me a cd with them on there, for 600 dollars i dont think it would have been that much of a pain. oh well live and learn
Old Sep 23, 2007 | 10:34 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
thats probably a vga port, not serial. Different number of pens.
Go and get a usb to serial converter cable and windows xp laptop.
Old Sep 23, 2007 | 10:40 AM
captj3's Avatar
captj3
You can even hook up to the usb port on the utec. Plus you can download the hyperterminal progam from the TXS web site.
Old Sep 23, 2007 | 11:13 AM
QuadCam's Avatar
QuadCam
that's the volume ****. turn it up to 11!!!
just kidding. on the TXS webiste, part of the download ARE THE USB DRIVERS.
since GTM did the tuning for you, you should probably contact them and have them walk you through setting up and interfacing the utec through a direct usb cable. I don't know how there customer service is, but hopefully they have someone on staff to help you. you can figure it out yourself from the manual, but it can be troublesome for some users.
Old Sep 23, 2007 | 12:23 PM
kevin8086's Avatar
kevin8086
i called yesterday and they said they would call me back, this was at like 9 in the am so it was early and yeah i never got a call back.
Old Sep 23, 2007 | 12:33 PM
QuadCam's Avatar
QuadCam
have you downloaded hyperterminal to your vista computer yet? that is the 1st thing you'll need.
then, you should power up your computer, turn on the car, but you don't need to start it. connect your computer to the utec via a usb cable. use the usb port on your laptop, and the usb port on the utec. windows will try to install the utec; it'll ask you for drivers. use the supllied drivers that I said to download from TXS.
once all that is done with...you can proceed to setup a hyperterminal connection. since you'll be using the usb port on your comp, it'll give some sort of virtual com port. make sure the laptop and utec are connected to eachother when trying to figure out what com port you will be using. for all other connection settings, you should do what the TXS manual says to do.
Old Sep 23, 2007 | 01:10 PM
GTM's Avatar
GTM
Vendor - Former Vendor
Kevin,
Just got a hold of Sam, your map is on the number 2 slot. If you do decide to change the settings on the UTec (which I wouldn't recommend) read the manual a couple of times to familiarize yourself with the unit then proceed from there.
If you have any questions you can give us a call on Monday.
-George
GT Motorsports
Old Sep 23, 2007 | 06:36 PM
kevin8086's Avatar
kevin8086
thanks george, i would like to see what map is on the other settings, i put it on 3 and the car feels great, not pulling timing and running strong. i'll probably switch it back to 2 until i can figure out whats on 3. it just doesnt seem to pull hard enough on 2. it doesnt have that little extra kick in the pants
Old Sep 23, 2007 | 08:06 PM
Sam@GTM's Avatar
Sam@GTM
GT Motorsports
Kevin - You just can't get a car tuned for 91 octane and then go switching maps on the UTEC not knowing what the outcome will be, you are playing with fire. I had mentioned this to you before, you car was tuned very aggresively even for 93 octane. Your old map was running 20 degrees of timing on the top end, for a stock engine this is a ticking bomb.
What was saving you before is how the UTEC was setup, that for every time the car knocked the UTEC would pull 16 degrees of timing. That is the reason you were feeling what you were feeling even on 93 octane.
So we did correct the knock setting for 91, and tuned the with the proper timing tables for 91 octane fuel. You switching maps right now on 91 gas is asking for trouble.
I just got here to the shop to finish up some work, I will be giving you a call to make sure we are on the same page.
Sam
GT Motorsports
Old Sep 23, 2007 | 08:34 PM
rcdash's Avatar
rcdash
OMG, you can't go changing maps on the UTEC without knowing what you're doing! Yikes.
Listen to Sam and George and leave it on the right map (2). You can get the kick in your pants AFTER you build the motor. Better than a hole in your block .
Old Sep 24, 2007 | 02:52 AM
kevin8086's Avatar
kevin8086
Sam
GT Motorsports
well i did put it back, when i felt the car pulling like it did (i dont mean timing but putting back in my seat) i went to the pump and ran 100 like i did before the tune. i'm just wondering if this is the same map loaded on to most the different settings or if this may be a diferent map. i didnt know about this switch before and i think maybe i may have messed with it before the tune i am honestly not sure, so it could have been that this car was running a different map the entire time i had it and just days before the tune i messed with it and i guess i could have put it on that setting with that aggressive timing. If the car was actually on this tune for the past year and a half i wonder how it held together because i know the car has been run harder than probably any car on here, for countless drift events, auto x, and a few track days and not to mention being on the dyno for a complete day when it was tuned at different times, were talking 6-8 hours on dyno and road time with just breaks to let it cool off and still this motor purrrrrs like a kitten. i just couldnt imagine that there is that big of a difference between 91/93, i know there is a difference but i didnt think 40-45 whp worth but i'm far from experianced with cars or tuning so this was just what was what i was thinking there is no actual knowledge on my part for this.
Old Sep 24, 2007 | 05:05 AM
merlin3's Avatar
merlin3
boom
Old Sep 24, 2007 | 05:51 AM
kevin8086's Avatar
kevin8086
Originally Posted by merlin3
boom
ummm ok, yeah i'm sure after a year and half of hard abuse i going to just blow it driving on the street with 7-8 psi.
NissanZcrazy
Nov 2, 2015 06:03 PM
2ndchanceZ
Oct 26, 2015 08:03 PM
Mike@Altered
Tuning
149
Oct 30, 2009 01:07 PM
BlackTuner
Nov 14, 2005 12:40 PM
