AAM vs. CJM fuel systems
Old Sep 25, 2007 | 11:12 AM
SpoilsofWar's Avatar
SpoilsofWar
Default AAM vs. CJM fuel systems
A RFS is one of the last components I need before I start my TN build...
SO I'm trying to decide whether to go with the CJM stage II or the AAM rfs. HP goal is in the neighborhood of 450whp, but I'm trying to leave myself a little headroom to increase power in the future if I want. From researching it seems either will more then do the job, and really the only negative thing I could find about either was something about leeching fuel lines on some AAM systems. Any particular reason I should go with one or the other?
Old Sep 25, 2007 | 11:19 AM
sentry65's Avatar
sentry65
the burninator
cjm is better
car won't smell like fuel
Old Sep 25, 2007 | 11:21 AM
SpoilsofWar
So the leeching issue with the AAM lines is really that common and severe, huh?
sentry65's Avatar
sentry65
the burninator
i couldn't say, but the CJM has more coatings of various materials on their fuel lines
Old Sep 25, 2007 | 12:37 PM
roncfpz's Avatar
roncfpz
Yes, I've had it since day one. Also, some of their fittings broke apart when FP did my engine build. Def go CJM.
Old Sep 25, 2007 | 12:49 PM
synth19's Avatar
synth19
CJM, no question.
Old Sep 25, 2007 | 12:53 PM
BestThreadEver's Avatar
BestThreadEver
CJM FTW, you dont want that fuel smell that the AAM one will give you.
Old Sep 25, 2007 | 12:58 PM
clemlover15's Avatar
clemlover15
Originally Posted by sentry65
cjm is better
CJM 110% better hands down don't even think about it just get that one!!!!
Old Sep 25, 2007 | 01:00 PM
clemlover15
AAM = crapy cheaper built
CJM = high quality perfection, invest in the best///lol
Old Sep 25, 2007 | 01:01 PM
Blackbird CPV35's Avatar
Blackbird CPV35
CJM +1111111, Charles responded pretty quickly when i had questions about installing it as well
Old Sep 25, 2007 | 01:21 PM
SpoilsofWar
Well I guess that pretty much settles it. Thanks guys.
Old Sep 25, 2007 | 01:22 PM
Gman2004's Avatar
Gman2004
I am not saying the CJM isn't better, but I've never had problems with my AAM fuel system. I don't really have a fuel smell either. I did try to buy a CJM, but this was two years ago and it wasn't on Charles' website at the time. He also had previously closed his shop so I couldn't call him to order. I just ended up getting what I could.
Old Sep 25, 2007 | 01:24 PM
GTM's Avatar
GTM
Vendor - Former Vendor
CJM Stage 2 on my personal car
-George
GT Motorsports
Old Sep 25, 2007 | 01:27 PM
Philthy's Avatar
Philthy
Boost Junkie
Never had any issues with my aam setup, and no fuel smell...
Old Sep 25, 2007 | 01:30 PM
rrmedicx's Avatar
rrmedicx
CJM. No Competition - running Stage 2..no problems
Old Sep 25, 2007 | 01:35 PM
booger's Avatar
booger
I think the early AAm systems had the cheap fuel lines that leeched fuel . They may have changed the lines later on , when or if they did I dont know . I know I have the cheap *** fuel lines . My garage smell like gas every day .
Old Sep 25, 2007 | 01:54 PM
BestThreadEver
they never changed them. They all stink!
Old Sep 25, 2007 | 02:55 PM
failsafe306's Avatar
failsafe306
I had no issues with my AAM system, and it never leaked or smelled of fuel in my garage.
Old Sep 25, 2007 | 03:00 PM
booger's Avatar
booger
So what is it exactly that is the problem with them ? Most are getting the bad results while others dont . Is it the fuel lines , fittings , or both ? We have check my fittings over and over and ended up with the leeching fuel lines conclusion .
Old Sep 25, 2007 | 03:10 PM
failsafe306
The only problem I had as far as fuel smells go, is when my 1000cc's were installed, they didn't grind the plenum to allow for the raised fuel rails, and when tightening down the lower plenum, it squashed my injectors down too far in the rails, tearing the o-rings, and resulting in a fuel leak. Def nothing to do with the FRS.
