question about tt
Old Sep 30, 2007 | 12:28 AM
uniqueIllusions's Avatar
uniqueIllusions
Default question about tt
Alright just a quick question lets say i get a fully built motor and and an aps tt kit. What else do i need. I know you can't just slap this on and be done with it. What about the tranny, axels, tires, suspension etc. is all this other stuff neccessary or not. If it is what else exactly would have to be done to run 600 + hp.
Old Sep 30, 2007 | 12:58 AM
r_seng's Avatar
r_seng
there are tons of answers to your questions. search is your best friend.
too much info the list down.
Old Sep 30, 2007 | 01:00 AM
r_seng's Avatar
r_seng
https://my350z.com/forum/fi-faq-s/112693-how-to-do-twins-right-the-first-time.html
Old Sep 30, 2007 | 01:01 AM
SpoilsofWar's Avatar
SpoilsofWar
^ +1, everything you're asking has been asked and anwered... Just look through the FI forum for a bit.
Mainly, you will need fuel. fuel, fuel, fuel.
Old Sep 30, 2007 | 07:29 AM
Zivman's Avatar
Zivman
Then a proper EMS to control all that fuel, a cooling system able to keep the heat down, a clutch/trans that can hold all the power you make, then worry about the tires and such
Old Sep 30, 2007 | 09:17 AM
uniqueIllusions
i know that part about fuel and the ems which are all included in the aps tt kit.....what i wanna know is am i gonna have to do suspension or can i just run my car with the stock suspension then also will my tranny be able to hold this power if not what kinda things do i need to look at. Also axels i dont wanna have all that power and be snapping axels left and right.
Old Sep 30, 2007 | 09:25 AM
abyss's Avatar
abyss
This is why you need to actually read through old posts. Also we cant answer about your suspension, tires, axles unless we know what your goals of the car are. Pure street, track, drag strip.. Of course out of common sense you dump that kinda $ under the hood I'd hope you have some sort of adjustable suspension. As far as axles you are fine on stock lvl 1 axles unless your doing really hard launches. If the parts raper Alberto's axles lasted as long as his did your not gonna have alot of worry there.
Old Sep 30, 2007 | 09:30 AM
failsafe306's Avatar
failsafe306
Old Sep 30, 2007 | 09:47 AM
leeboyNY's Avatar
leeboyNY
Kimchi Eater
Oh boy... I should just tell you to hit the "SEARCH" button, but since I already have the list to copy and paste... here it is... Some of the items are optional.. But you will need 90% of the items listed below.
Engine:
* GTM stage 0 short block
* 06' Rev-up oil pump upgrade
Turbo:
* APS twin turbo kit
* Forge actuators with 1.5bar boost springs
Head:
* GTM turbo spec cams
* JWT high cam springs and shims
Fuel:
* CJM stage 1 fuel return system
* Walbro 255l fuel pump
* SARD 1000cc low impedance fuel injectors
Drivetrain:
* Carbonetics/ATS twin carbon clutch with 1350 pressure plate
Exhaust:
* APS 3.5" test pipes
* Greddy EVO TT 3" true dual exhaust system
Cooling:
* PWR 40mm dual core radiator
* Samco silicon hoses
* Pathfinder SUV cooling mods
EMS:
* F con V Pro version 3.21 or better + pressure sensor + intake air temp sensor
Gaskets & tie towns:
* Nissan engine rebuild gasket kit
* HKS head gaskets
* ARP L19 head studs
Old Sep 30, 2007 | 10:54 AM
SaadSindhu's Avatar
SaadSindhu
The APS extreme kit comes with proper fueling for 600whp levels, not the APS TT Kit. If your looking at the APS TT kit, you may have to get a complete fueling kit separately. I believe the APS fuel kit is around 1500 bucks. Other than that leeboyNY has pretty much listed everything else you will need.
Old Sep 30, 2007 | 03:39 PM
MethodRN's Avatar
MethodRN
For Sale
oh yeah you'll also need this...
Other than that, just take a day off work (or do it at work), sit at the comp, have food and drinks within reach and read all the great info in the Tech area.
Old Sep 30, 2007 | 04:27 PM
XKR's Avatar
XKR
OK.....because you all were nice enough to answer the OP questions....it would only be fair for you all to answer mine....... I did a search and could not find an answer.......
How much RWHP can you get from a Sticker??? For example an HKS sticker??
Old Sep 30, 2007 | 04:57 PM
andyisphat2004's Avatar
andyisphat2004
is it going on a 350z or a civic?
Old Sep 30, 2007 | 05:39 PM
XKR's Avatar
XKR
G35
Old Sep 30, 2007 | 07:00 PM
leeboyNY's Avatar
leeboyNY
Kimchi Eater
G35
Hmm~ then -50WHP..
Old Sep 30, 2007 | 08:06 PM
uniqueIllusions
it also depends on the location
Old Sep 30, 2007 | 08:50 PM
usingthejohn's Avatar
usingthejohn
windshield stickers free up about 45whp.
for BIG power, put a roll call along the drivers' and passengers' doors...that's almost 150whp.
Old Oct 1, 2007 | 01:43 AM
NETSHARK's Avatar
NETSHARK
Looooooool
