Starting problem
Old Oct 3, 2007 | 08:41 AM
moog's Avatar
moog
Default Starting problem
Modifications:
Vortech SC w/ 3.12 pulley
440cc injectors
Skunk2 plenum spacer
Walbro 255 fuel pump
UTEC
The car runs great. The only problem I have right now has been occuring over the the past two weeks. After I fill up on gas, the car cranks and cranks but does not start. It takes about 2-3 tries of extended cranking for the engine to slowly start up and sputter to life. The car will then stall. I retry cranking, give it some gas, and the car sputters to life again. I'll have to blip the throttle for about 30-45 seconds for the car to finally stabilize and hold an idle. This only happens immediately after I fill up on gas. Anytime after the car starts fine.
What do you guys think the problem may be?
Old Oct 3, 2007 | 08:50 AM
SFMACGUY's Avatar
SFMACGUY
feul delivery system. Are you running the car extremely low on gas ( gas light comes on) as that can wear out the fuel pump faster. It sounds like your running it low, and then the fuel pump is having to prime itself ( get gas back into it). Depending on how old it is, it may be time to replace.
Old Oct 3, 2007 | 10:25 AM
moog's Avatar
moog
Yeah it's below 1/4 tank when I fill up on gas. It's a 2 month old Walbro 255. This only happens after I fill up on gas. When I start the car up in the morning, even if its low with the gas light on this does not happen. Even if I turn the ignition on and let the fuel system prime for a few seconds it still happens.
Old Oct 3, 2007 | 10:41 AM
SFMACGUY's Avatar
SFMACGUY
id get it waranteed out then, I am 95% sure its something with the fuel pump. You could always get the fuel filter replaced to see if its dirty ( like 60 bucks)
Old Oct 18, 2007 | 12:45 PM
moog's Avatar
moog
anyone else have this problem?
Old Nov 13, 2007 | 07:44 AM
moog's Avatar
moog
bump ... this problem is still going on...any insight?
Old Nov 13, 2007 | 08:11 AM
go-fast's Avatar
go-fast
sounds like when the cap is off the fuel from the line is draining back into the tank,do you have a fuel pressure gauge?
Old Nov 13, 2007 | 10:33 AM
moog's Avatar
moog
No fuel pressure gauge. I guess what I can do is possibly just undo my gas cap even w/ a full tank for a minute to see if I can recreate the problem.
Uriyo_
Sep 8, 2021 08:46 AM
