swapping with 1jz fuel injectors 1000cc
Old Oct 6, 2007 | 03:13 PM
rk2334's Avatar
rk2334
Smile swapping with 1jz fuel injectors 1000cc
Hello guys I think this forum is the best forum found on net for 350z.
Recently have bought used Greddy TT without fuel injectors and I found a good used cheap 1jz fuel injectors 1000cc.my question Does it fit or not to install in 350z? should i buy it?
Old Oct 6, 2007 | 03:24 PM
Zridder19's Avatar
Zridder19
no buy injectors for a 350z!!
Old Oct 6, 2007 | 04:31 PM
VIZAGE's Avatar
VIZAGE
I would also think most injectors are different for all brands of cars. Especially the injector harness clips.
Old Oct 6, 2007 | 07:22 PM
craigo'sznprgrs's Avatar
craigo'sznprgrs
If you are price conscious, look on the classified, and get all car specific parts, it will usually take away many headaches.
Cheap 550cc-750cc injectors are very easy to find usually less than 400 shipped.
Craig
Old Oct 6, 2007 | 08:33 PM
Nealoc187's Avatar
Nealoc187
1000cc/min injectors are almost certainly low impedence injectors, so no, they would not work. you'd need engine management with a low impedence injector driver - not to mention the fact that they won't fit (1jz uses side feed injectors, 350z uses top feed injectors, so you' have to do customization in that respect as well.)
www.deatschwerks.com has good prices on quality injectors that will drop in your current fuel setup without any modification, I and many of my friends run them in cars ranging from 300-600whp. they do international shipping too (I noticed you are in UAE).
Old Oct 7, 2007 | 03:22 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
+1 on the deatschwerks, i use them in almost all my project cars and have had no issues at all.
pm me if you would like to order some...
Old Oct 7, 2007 | 10:28 AM
VIZAGE's Avatar
VIZAGE
Deatschwerks works great for me so far on my TN kit. Have the 550cc. Wish I would went with the 650cc. Not a big deal at all. For the % on the duty cycle is perfectly fine.
Old Oct 7, 2007 | 08:40 PM
Weqster's Avatar
Weqster
350Z injectors are the same found in alot of honda's.
and many many many other cars. U can use supra injectors but require a resister pack depending on which market the supra was from.
Old Oct 8, 2007 | 03:39 PM
rk2334's Avatar
rk2334
Thanks guys
