Vortech bypass valve can be replaced?
Old Oct 19, 2007 | 12:30 AM
Everybodywildou's Avatar
Everybodywildou
Default Vortech bypass valve can be replaced?
Can the vortech bypass valve be replaced with a BOV? From what I understand it can be replaced with a pull type like the HKS ssqv.
Old Oct 19, 2007 | 08:20 AM
Everybodywildou
Old Oct 19, 2007 | 10:15 AM
booger's Avatar
booger
I tried it and couldnt get it to work . Even taking out one of the springs . Maybe I took out the wrong one...dont know . Others said they have been able to make it work . Might want to do a search on it
Old Oct 19, 2007 | 11:55 AM
Quamen's Avatar
Quamen
If you can get it to open at minimal vacuum it should work. This would require you to take the spring out though and get a different one from Mcmaster with a lower cracking pressure (vacuum actually).
Old Oct 23, 2007 | 12:44 AM
Everybodywildou
Hmmm have you tried it and been successful with it? I would really like to put my friends greddy type-s on.
Old Oct 23, 2007 | 08:04 PM
Everybodywildou
bump for more responses
Old Oct 23, 2007 | 08:07 PM
Nexx's Avatar
Nexx
even if you could do it, what would be the purpose? mine is so damn loud, anyway i could reduce the shhhhhhhhhh sound?
Old Oct 23, 2007 | 08:09 PM
Everybodywildou
I guess basically for a different tone. I prefer the hyper pitch rather than the whoosh of air.
Old Oct 23, 2007 | 11:39 PM
Quamen's Avatar
Quamen
Restrict the hole somehow and you will get a whistling sound like the SSQV
Old Oct 26, 2007 | 09:36 PM
Everybodywildou
I'd rather replace it instead. lol
Old Oct 26, 2007 | 10:47 PM
Everybodywildou
Oh heres another question, why does the vortech bypass valve stay open at idle?
Old Oct 27, 2007 | 06:36 AM
moog's Avatar
moog
It's not supposed to be open at idle. If it is, then you have yours adjusted too loosely. I think the consensus on the forums is about 6-7 threads showing.
Old Oct 27, 2007 | 09:29 AM
booger's Avatar
booger
Moog...the Vortech bypass -bov is ALWAYS OPEN at idle . It closes when vacuum drops [ more throttle ]
Old Oct 27, 2007 | 01:13 PM
Everybodywildou
so a BOV stays shut correct? So I'm assuming the only way to make a BOV work is get a looser spring?
Old Oct 27, 2007 | 02:02 PM
booger's Avatar
booger
Thats waht Ive been told ....and I tried it...But it didnt work for me . OtherS have said that it worked for them.
Old Oct 27, 2007 | 02:11 PM
MUZZY's Avatar
MUZZY
I would not recomending for anyone to do this.
need to understand that there is a difference from the BOV and BPV.
you can buy other bypass valves that have diferent sound.
Old Oct 27, 2007 | 07:56 PM
Everybodywildou
I don't mind you saying that. But tell me why not. It's just that I find that the whoosh will sound will get tiresome.
Old Oct 28, 2007 | 07:43 AM
booger's Avatar
booger
If you want to get rid of the sound . Re-locate the bypass-bov to the other side of the intercooler and run a hose from the bov back to the intake .
Old Oct 28, 2007 | 08:49 AM
MUZZY's Avatar
MUZZY
if you do not like the whoosh sound vortech sells a filter that attaches to the BPV witch almost eliminates it
Old Oct 28, 2007 | 03:00 PM
Everybodywildou
Ohhh no I guess I should have worded it better. I'm looking for a different sound.
