Limits of the JWT clutch and flywheel
Old Oct 23, 2007 | 08:48 AM
Philthy's Avatar
Philthy
Boost Junkie
Originally Posted by chris'smax
its the voodoo version of the jwt clutch
voodoo clutch & flywheel now too...
Old Oct 23, 2007 | 08:51 AM
XKR's Avatar
XKR
LMAO
Old Oct 23, 2007 | 09:28 AM
Devil Z's Avatar
Devil Z
Just let it go man.
Old Oct 23, 2007 | 09:35 AM
Alberto's Avatar
Alberto
Cranky FI Owner
edit--->ban = no good
Old Oct 23, 2007 | 09:59 AM
rr_z33's Avatar
rr_z33
Old Oct 23, 2007 | 10:03 AM
__jb's Avatar
__jb
Z + Rear Seat
My comment was in reference to the TQ 'curve' - the scaling doesn't change the fact that it's ugly as heck - peak and then complete drop off... I also haven't seen a car make more HP than TQ below 5250rpms...
Isn't that supposed to be because the clutch is slipping... therefore... no torque?
Old Oct 23, 2007 | 10:06 AM
QuadCam's Avatar
QuadCam
It doesn't drop off as much as it looks......again, it is because of the different values of the left and right axises (sp?) of the graph that throw off the way the graph looks. the same goes for what looks like the car is making more HP than TQ below 5252, also.
for example, look at 3000 rpms. It looks like the engine is making more HP than TQ, but if you look at how the values on each side of the graph, you'll see that: at 3000 rpm, HP is approx. 150hp , while TQ is approx. 285 ftlb.
Old Oct 23, 2007 | 10:12 AM
IIQuickSilverII's Avatar
IIQuickSilverII
so you are bashing jwt now 2?
Old Oct 23, 2007 | 10:17 AM
IIQuickSilverII
Originally Posted by XKR
How could they be standard ones Scott? At first I had Sharif install a RPS Clutch and Flywheel that was good for up to 600 rwhp, but he burned it out on the dyno with just a few runs....it could not hold the TQ. I just cannot see a standard clutch holding that much TQ. Did your clutch hold because of the kind of dyno you used ?
Originally Posted by Audible Mayhem
we have made 620 to the wheels in 5th gear in a Z on race gas with the JWT combo, no doubt that its a good clutch combo thats affordable..
conflicting info here xkr makes 558 rwhp 564 tq (per his sig)
plus i know another car by FP that puts 550whp too with the RPS max 6-puck clutcha nd flywheel all day long with no issues so far
so....
EDIT
but the i dont believe the jwt can handle 600+whp or the 550whp with track use...
but it happens to be what mike b runs
Old Oct 23, 2007 | 10:18 AM
Philthy's Avatar
Philthy
Boost Junkie
The only negative comment I've ever had for JWT is the people they choose to associate with in the past...
You have three or four people in this thread basically saying the same thing that I am but you want to single me out...
Old Oct 23, 2007 | 10:29 AM
IIQuickSilverII
well you just called their product voodoo...
ovbiously not a huge offence... but that was targeted to the clutch itself
EDIT:
SORRY you didnt do it first
Old Oct 23, 2007 | 10:30 AM
WA2GOOD's Avatar
WA2GOOD
As for the clutch. It is a standard organic style that has been in the car for almost two years. I am just as surprised as anyone about what it has withstood. I would not recomend this type clutch for more than 600 tq/hp but, my only point was that these clutches are under-rated.
As for this car, yes, this car IS making 700 whp at 18psi with the JWT 850BB kit and even 749 at 20psi. wether people want to believe it or not. And for the record this car DOES have the stock type head studs and head gasket It always has. Not the pretiest dyno chart but we were not finished with this car at this point, that chart was only posted to illistrate the clutch slipping, not to be disected.
And lastly, the JWT Dyno (aka the moon dyno) is every bit as acurate as a dyno Jet and I have already proven that point in another thread, and when this car is ready to tune again with the new cams and clutch we will run the car on 3-4 different dyno's that are owned and operated by different people.
Not trying to start a debate or a bash fest here, LOL. Some of you guys are too much and just love to argue.
Old Oct 23, 2007 | 10:40 AM
WA2GOOD's Avatar
WA2GOOD
One more time.....Here is an example of a DynaPack vs DynoJet comparison that we did on a customers car a couple weeks ago. These are of the same car, same gas (91oct), same boost levels, same temperature. One was done the very next day, at the same time of day. The DynoJet was just for a couple power pulls, just to confirm and back up the JWT DynaPack numbers for you all. As you can see, the 16psi runs are almost identical numbers, but the 14psi shows the DynoJet to have a bit higher numbers.
(Note-this is not the same car as the above posted, this car has the 700BB kit on it with meth/H2o., this is Gammawolf's brothers car)
Old Oct 23, 2007 | 10:46 AM
Philthy's Avatar
Philthy
Boost Junkie
Not arguing or bashing - question, is it a stock 'TYPE' or is it 'STOCK' when you reference the head studs and gasket...
Truly not believable, but if you say so...
Old Oct 23, 2007 | 11:02 AM
WA2GOOD's Avatar
WA2GOOD
(Sory, I will edit it for you.)
Head studs and gaskets are STOCK, ORIGINAL EQUIPMENT MANUFACTURER (OEM). You do not have to believe it, I do not loose any sleep at night wondering if you believe me or not. But, you and anyone else are ALWAYS welcome to come see it for yourself.
Old Oct 23, 2007 | 11:09 AM
SinCity350Z's Avatar
SinCity350Z
Track Whore
I understand where Philthy and others are coming from, I would probably be upset too if I spent a lot of extra money overbuilding every aspect of my car/motor with seemingly un-necessary components when others are spending less and acheiving comparable, or better results.
If this causes this kind of debate, I hate to see what comes from posting whatever results we get once the new clutch and cams are in. And yes, they will be from both Jim's dyno and a DynoJet.
Old Oct 23, 2007 | 11:24 AM
dutchboy's Avatar
dutchboy
How are aftermarket head studs/headgaskets overbuilding when the OEM parts have failed over and over again on FI motors?
Old Oct 23, 2007 | 11:26 AM
  #38
XKR's Avatar
XKR
I dont understand your point....are you thinking I am still using the RPS clutch system? If so... I am not...the RPS did not make it off the dyno. Sharif had to change it to Carbonetics Triple Disc Carbon Clutch.
edit: My statement about the RPS clutch system is a discription of what the RPS system was rated at 600rwhp....not that my car dynod at 600rwhp BTW on a DJ...I can make it over 600rwhp. The RPS system when it was on my car (on the dyno) did not make it pass 500 rwhp.
  #39
Nitrouz's Avatar
Nitrouz
Back to Z
IIQuickSilverII: Please stop posting in EVERY conflict thread, and just try to pick on people's words to induce even more conflict when nothing is about you. You don't have this part, you've never tried this part, and you have nothing to contribute to it. So stay out of this thread. And the same goes for EVERY other conflict thread. We've been watching you for a while, so consider this your first and final warning.
Everyone else, please carry on and keep in mind the rules that are being enforced.
Old Oct 23, 2007 | 11:28 AM
  #40
XKR's Avatar
XKR
+10000000000
