Aps Extreme Vs Aps Tt
Old Oct 26, 2007 | 08:59 AM
350zDCalb's Avatar
350zDCalb
builtZmotors
Exclamation
I have run the aps standard tt setup for a while now. On 18psi with a 96 octane/ methanol injection tune, I made 570rwhp and 615tq... on some C16, I'd be able to run lots more timing and make a bit more I'm sure
The turbos spool so quickly, and make more than enough power for the street... I drive on a low boost setting of 13psi, which I assume makes high 400's (never dynoed at low boost)- and this is plenty for daily driving-- losing traction in 4th gear on high boost is a bit scary for everyday use
oh, this is on an unsleeved bottom end, 1/2" head studs, hks headgaskets, cams, and jwt valvesprings- besides that completely stock heads...also, that's with slightly larger oil clearances on the mains and rods, running strong!
Old Oct 26, 2007 | 09:06 AM
danisr1's Avatar
danisr1
Sleeps in 350Z
Originally Posted by Audible Mayhem
all real turbos have lag...
Amen to that
Old Oct 26, 2007 | 10:46 PM
gecof1's Avatar
gecof1
Newbie
I have the short block. Nothing done on head.
Old Oct 27, 2007 | 12:29 AM
ShamrockG's Avatar
ShamrockG
Hahaha.... Maybe, but lag sucks for usable power on the street or roadcoures.
IMO, turbo lag =
Old Oct 27, 2007 | 06:17 AM
Zivman's Avatar
Zivman
I would highly suggest a set of cams. it is going to be tough to make it to 600 without them
Old Oct 27, 2007 | 10:11 AM
SaadSindhu's Avatar
SaadSindhu
One way to go about it is just pull out your complete APS tt kit. Sell it, and buy the extreme kit which will come with all the fueling and small gaskets etc. that you will need. Since you already have a built motor, it will be nice. The power delivery of the extreme kit is SICK, i dont know why everyone is saying its laggy..i had a gsx with a gt35r, that was laggy. My buddy has a turbo s2k and that is laggy. ****...the evo's are laggy. NOT the extreme kit, man that **** gets up and goes. ANyways, i was saying...I sold my tt kit complete for 6 grand, an ASP fuel system will cost 1500 bucks. The extreme kit is 9 grand, or was when i got it. At the end of the day swwapping over to the extreme kit cost me 1500 bucks plus cost of upgraded clutch, (went with exedy twin disc D-core and it slips after 5k rpm so i would suggest going with maybe a tripple disc, and they are cheaper too), also for my ems i switched over to the HKS F-con which is also kinda pricey.
Im not sure how reliability will be affected when tuning the APS TT kit to that sort of power levels. I had a TT kit on my car for about a year but with stock internals, last year i sold that and put in the extreme kit once my motor was built/sleeved, etc. At 11 psi my base TT kit made mid 400's whp. Just tuned my car a few weeks ago, on 93 octane it made 640 whp at 15 psi.
Old Oct 27, 2007 | 10:16 AM
KempieZ's Avatar
KempieZ
I have a standard aps tt kit and had everything changed to the extreme kit except the turbo's. The standard turbos spool much faster and I am aiming for 700 hp on the block, which is more than enough for a street car. ( but I do have cosworth heads) i hope the turbos will last at those power levels. I read they can handle 800 so I dont think there is any problem.
Old Oct 27, 2007 | 10:27 AM
SaadSindhu's Avatar
SaadSindhu
^Not sure about turbos but from my experience comepanies always project very optimistic levels of performance for their products. According to Exedy a twin carbon clutch will hold up to 800 lbs of torque and mine wont hold more than 600whp, once it hits 600 its starts slipping.
Old Oct 27, 2007 | 10:35 AM
KempieZ's Avatar
KempieZ
Yes, i realize that. I definately wont go over the 700 mark but I have my doubts with those power levels. From what I have heard and seen, anything above 650hp on the block is almost lost. No traction and no joy to drive.
Old Oct 27, 2007 | 10:37 AM
Devil Z's Avatar
Devil Z
The homie I bought my APS TT from knew BigBri; he said Brian would smoke EVERYTHING on the streets but the car could NEVER hook up for the life of it, and that it wasn't as enjoyable as his APS TT with 430whp.
Old Oct 27, 2007 | 10:47 AM
SaadSindhu's Avatar
SaadSindhu
Traction definitely will become an issue, again it depends on ur use for the car. I know Brian as well, and have see his car in action on the highway tons of times. It is SICK and his ability to manhandle his car is unbelievable. In lower gears it would suck, but once all the small glitches are worked out i find getting traction on the highway in 3rd and higher gears is very doable in the mid 600 whp range. And dont get me wrong, when you get on it in 1st or 2nd and the car just lets loose, shoot...it dont matter if your going anywhere or not. The car screams and you hear the vacuuming of those nice size snails, i enjoy letting it kick out in 1st and 2nd sometimes. But it does get annoying when a sti or something else thats close to stock is tryina race me out of a dig and i cant get traction.
APS EXTREME kit IMHO is strictly for high end.
Old Oct 27, 2007 | 10:52 AM
Cannysage's Avatar
Cannysage
I pretty much agree. even At 500whp, there's no traction til 40mph. you never know when the other guys even racing you, cuz when it's over, you teleport about, 2 star trek voyager lengths on him. there's none of the 'gradual pull' high you get from a lower powered car.
Old Oct 29, 2007 | 06:17 AM
gecof1's Avatar
gecof1
Newbie
Any suggestions on maker? I am pretty much confused.
Old Oct 29, 2007 | 06:37 AM
Zivman's Avatar
Zivman
a lot of decent cams out there.
I am running the GTM stage 1 FI cams. I have heard mixed reviews of them, but my tuner thought they were decent and that they made power. GTM now has a stage 2 cam set for FI. I saw some decent results from brian crower cams on the boards. Other wise, there is the old stand by C2 JWT cams.
Old Oct 29, 2007 | 10:22 AM
DanielW's Avatar
DanielW
+1 with the amount of money you would have to spend on upgrading to the extreme setup a set of cams would help alot in reaching your goal and be cheaper
Old Oct 29, 2007 | 12:07 PM
Jonny Boy's Avatar
Jonny Boy
One advantage to the extremem kit is the power is much more linear and come on very smooth. As with the smaller turbo's the power comes on a lot sooner and very hard and can almost become violent when accelerating. Although I do not have turbo's yet, , many of my friends do. only one of which has the extreme kit, and all others are greddy tt. I will be getting the extreme kit or the jwt 850 kit. With the larger turbo's the car seems to drive like a normal 350z when not in boost. Personally I like the smooth power delivery of the larger turbos.
Old Oct 29, 2007 | 03:18 PM
  #38
Nitrouz's Avatar
Nitrouz
Back to Z
totally the opposite.
Old Oct 29, 2007 | 04:43 PM
  #39
DanielW's Avatar
DanielW
yeah it seems like the bigger turbos would come on harsher because they lag and then BAM
Old Oct 29, 2007 | 06:08 PM
  #40
SaadSindhu's Avatar
SaadSindhu
The power delivery does come on smooth with the extreme kit.
