Waste gate question
Old Oct 31, 2007 | 10:05 AM
RED HOT Z's Avatar
RED HOT Z
Default Waste gate question
Is there any 48mm waste gate that will bolt up to where the existing TN's waste gate is?
Thanks
Gilbert
Old Oct 31, 2007 | 10:55 AM
aj_350z's Avatar
aj_350z
the tial 38 mm will bolt right up. the tial 44mm requires welding on a new flange.
Old Oct 31, 2007 | 11:00 AM
RED HOT Z's Avatar
RED HOT Z
I need one that will work with my set up. I am looking to max out the TN's kit with my built motor. Which waste gate should I get?
Old Oct 31, 2007 | 11:10 AM
taurran's Avatar
taurran
I'd rather just weld on the new flange with the Tial. You could also just buy a Tial 38mm gate and bolt that right up, but I'm not going to guarantee anything. I'm not sure which gates come with the same two bolt flange, but there may be others that will swap out.
Old Oct 31, 2007 | 11:52 AM
RED HOT Z's Avatar
RED HOT Z
What size wastegate do you think will be sufficient for my goals?
Old Oct 31, 2007 | 12:42 PM
MIAPLAYA's Avatar
MIAPLAYA
The RG-45 wastegate Turbonetics is releasing at SEMA I believe bolts up to the same flange. Its a 45mm wastegate...
Old Oct 31, 2007 | 12:59 PM
IIQuickSilverII's Avatar
IIQuickSilverII
44-45mm will works well even on 1500whp supras
so u can try the tial or the one Miaplaya suggested
Old Nov 1, 2007 | 11:03 AM
RED HOT Z's Avatar
RED HOT Z
How much is the new RG-45? If its to much I'll just get the Tial 44mm.
Thanks guys
Old Nov 1, 2007 | 11:11 AM
MIAPLAYA's Avatar
MIAPLAYA
Thanks guys
I'm not sure what the MSRP is yet. It was just released this week.
Old Nov 1, 2007 | 11:15 AM
RED HOT Z's Avatar
RED HOT Z
ok cool
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
