Car is running lean, tuner can't fix (vortech)
Old Nov 7, 2007 | 12:03 PM
lve2xlr8's Avatar
lve2xlr8
Yea i mean I'd like to do everything within my ability before I go to a shop but thanks for the info, do you have their contact info?
Old Nov 7, 2007 | 12:18 PM
GlenRoseFireFighter's Avatar
GlenRoseFireFighter
http://home.earthlink.net/~spchurch/...sting/id2.html
Old Nov 7, 2007 | 12:29 PM
Eazzy's Avatar
Eazzy
Just for a laugh. are you running a # 6 Plug ???...Check color. Chk your vacuum at all points for accuation. Including Plenum for Bottom Line Vac. Stock Injs. should be fine with that pulley
These are cheap Checks
Old Nov 7, 2007 | 03:06 PM
RA11325's Avatar
RA11325
Originally Posted by diwun67
Dude you can't run a 3.12 pulley with stock injectors, at least I don't think. Get yourself some 440cc's and re-tune.
Yes you can, I am on stock injectors and I keep my airfuels in the high 10's at redline.
Old Nov 7, 2007 | 03:08 PM
Eazzy's Avatar
Eazzy
Ditto for mine
Old Nov 7, 2007 | 05:15 PM
lve2xlr8's Avatar
lve2xlr8
Dyno Sheet Posted
Old Nov 7, 2007 | 05:20 PM
lve2xlr8's Avatar
lve2xlr8
Default Dyno Sheet Posted
Here it is again... As you can see the air fuel is horribly lean...
Old Nov 7, 2007 | 05:55 PM
S12 driver's Avatar
S12 driver
Some people had received faulty SS Box before, you might want to check that out if everything else are fine.
Old Nov 7, 2007 | 06:11 PM
lve2xlr8's Avatar
lve2xlr8
Well SS is the one that tuned it and they said the box was fine..
Old Nov 7, 2007 | 06:25 PM
diwun67's Avatar
diwun67
When you come back up for The Run, you and I need to go for a little run
Old Nov 7, 2007 | 09:07 PM
lve2xlr8's Avatar
lve2xlr8
So I just went under the car and checked all the vacuum lines, they didnt seem to be very tight on the nipples (har har) so I zip tied all of them and went for a ride and it feels much better... I'm gonna take it in tomorrow to have another dyno run to see if it's better...
Crosses fingers...
Old Nov 8, 2007 | 02:05 PM
RA11325's Avatar
RA11325
I think we can make that happen.
Old Nov 8, 2007 | 02:06 PM
Blu_Blur's Avatar
Blu_Blur
Originally Posted by CUxtopher
do you have the 3.33 pulley? itd be best to put it on and then tune it.
there are plenty of people who would want a 3.12 pulley.
Yeah, STOCK injectors on a 3.12 pulley? No wonder you are running lean.
Old Nov 9, 2007 | 07:10 AM
eez's Avatar
eez
I had the same problem with a rev-up and unichip. I ditched the AUX pump and FMU for an in tank walbro 255, UTEC and 440cc injectors. Now i'm both rich and poor
Old Nov 9, 2007 | 10:02 PM
lve2xlr8's Avatar
lve2xlr8
so that was all it was!!! Car is running good now ex getting momentary losses of power above 110mph in 5th at wot
Old Nov 10, 2007 | 02:54 AM
DMK's Avatar
DMK
So, I'm guessing one of your vacuum lines was loose and the SS box was reading no or little boost and therefore not turning on the aux pump even though you were boosting.
Old Nov 10, 2007 | 08:00 AM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
I would question the tuner why he continued the dyno pull with A/F going into the 18's... WOT and under boost!
He should have aborted the run long before that.
You're lucky you still have an engine.
Old Nov 10, 2007 | 12:07 PM
  #38
lve2xlr8's Avatar
lve2xlr8
Yea my thoughts exactly
Old Nov 10, 2007 | 01:57 PM
  #39
Hydrazine's Avatar
Hydrazine
Ping may also have a lot to do with your HP going down so rapidly. Its well below 200HP at 6500 RPM? That's very low even if it was NA.
I'll bet heavy inaudible knock was hammering your engine above 5K RPM on the dyno. An A/F of 18 is about as bad as can be. Even if NA, 18 is high enough that it guarantees a very high ping rate, yet the ratio is low enough that there is still a lot of shock energy released in each knock. ...A nice optimum for knock. From a fuel/air explosive chemistry point of view, an A/F of 18 will ensure a high velocity and brissant shock wave.
Regardless, the dyno operator should have known to stop the run.
You probably shouldn't go back to that shop. And tell your friends to stay away from there too.
Even if latent damage to your engine is small or non-existant, the operator ran your engine through a risky mode of operation. Why take a risk like that?
Old Nov 10, 2007 | 02:04 PM
  #40
Julian@MRC's Avatar
Julian@MRC
The drop of power was due to a lack of fuel and most likely some detonation.The car simply did not have enough fuel to make the power asked of it. PROVIDING the belt was NOT SLIPPING on the dyno run, we have seen belts slip above 5000rpms and cause the car to go lean due to falling backward in the mapping to lower cell points.
However I 100% agree with Tony, as soon as the tuner saw it going the slightest bit lean, time to ABORT.Anyone who stays in it as either stupid, or REALLY stupid.. My advice,find anothe rtuner and give your car a REALLY good once over, something as minimal as a loose vacume line or wire, can cause engine failure. I suggest finding a shop that specializes in 350Z's or, believe it or not, Mustangs. Most mustangs have blowers and a shop familiar with them should be very familiar with a Vortech and Procharger set up and tune..
