Car is running lean, tuner can't fix (vortech)
Old Nov 10, 2007 | 02:06 PM
  #41
n1sm0r's Avatar
n1sm0r
Originally Posted by MRC Motorsports
The drop of power was due to a lack of fuel and most likely some detonation.The car simply did not have enough fuel to make the power asked of it. PROVIDING the belt was NOT SLIPPING on the dyno run, we have seen belts slip above 5000rpms and cause the car to go lean due to falling backward in the mapping to lower cell points.
However I 100% agree with Tony, as soon as the tuner saw it going the slightest bit lean, time to ABORT.Anyone who stays in it as either stupid, or REALLY stupid.. My advice,find anothe rtuner and give your car a REALLY good once over, something as minimal as a loose vacume line or wire, can cause engine failure. I suggest finding a shop that specializes in 350Z's or, believe it or not, Mustangs. Most mustangs have blowers and a shop familiar with them should be very familiar with a Vortech and Procharger set up and tune..
exactly what he said.
Old Nov 12, 2007 | 11:52 AM
  #42
lve2xlr8's Avatar
lve2xlr8
Thanks for the help guys, it's just hard to find a shop that tunes the SS box... Someone on here told me of a shop in Torrance that tunes the R4... The car seems to be running well right now but I'm gonna take it there asap...
Again thanks for everything!
Also, is there more potential of belt slippage at high rpm in higher gears 4-5-6
Old Nov 12, 2007 | 12:17 PM
  #43
GlenRoseFireFighter's Avatar
GlenRoseFireFighter
you can fix the slippage problem by replacing the belt the kit came with with a GATES belt...you can get them at NAPA.
Old Nov 12, 2007 | 01:14 PM
  #44
lve2xlr8's Avatar
lve2xlr8
Already got it, I don't think the belt is slipping... Is it pretty apparent from inside the car when it does?
Ughh I need money for some gauges!
Old Nov 12, 2007 | 01:29 PM
  #45
GlenRoseFireFighter
yes, especailly at night when there's dew...it'll squeal as soon as you turn it on.
Old Nov 12, 2007 | 05:44 PM
  #46
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Hey Randy!
Its been a while. What brings you back to the forums?
Are you working in the Glen Rose fire department now?
Tony
Old Nov 13, 2007 | 05:32 AM
  #47
GlenRoseFireFighter
Originally Posted by Hydrazine
Hey Randy!
Tony
I never left, I just sold the car. I'm thinking about getting a Z soon. How ya been? Yes, I'm with the Somervell Co. Fire Dept in Glen Rose, TX.
Old Nov 13, 2007 | 07:53 AM
  #48
THE TECH's Avatar
THE TECH
Originally Posted by Blu_Blur
Yeah, STOCK injectors on a 3.12 pulley? No wonder you are running lean.
There is no issue running the stock injectors with the 3.12
Old Nov 13, 2007 | 07:54 AM
  #49
THE TECH's Avatar
THE TECH
The OP really needs to get his car retuned before randomly deciding the problem went away. Take it to Chruch's and be done. To be blatantly honest, if you can't afford it, you shouldn't be doing any form of FI in the first place. Not a dig, just being truthful.
Old Nov 13, 2007 | 08:31 AM
  #50
lve2xlr8's Avatar
lve2xlr8
After you already put down 350 for a tune you don't leave a lot of room, I had the a/f tested and it's a tiny bit rich so it's safe to drive. Thanks for your input though.
z33z_nutz
Sep 23, 2015 07:22 PM
Upstreammiami
Sep 17, 2015 02:45 AM
Calinismo350z
Sep 14, 2015 04:04 PM
pdexta
Sep 14, 2015 11:27 AM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
