Vortech Question...
Old Nov 9, 2007 | 07:44 PM
rlwjr1's Avatar
rlwjr1
Default Vortech Question...
Just looking right now but I do have a question about pulleys. The kit come with a stock 3.33" drive pulley. This in turn rotates a 32 tooth cogged pulley and a 28 tooth cogged pulley on the SC itself.
When figuring impeller speed do you add the two drives together?
Example:
5.75(crank pulley dia.) x 3.54(internal step up) x 6500 rpm
3.33(blower pulley dia.)
This equals 39,731 rpm
32(toothed jackshaft) x 3.54 x 6500 rpm
28(toothed pulley on the SC)
This equals 26,297 rpm. Add the two together and I get 66,028 rpm. Seems high...
Maybe if I leave out the internal step up on the first equation? This gives me 37,520 rpm TOTAL
Am I figuring this right???
Old Nov 9, 2007 | 09:01 PM
Quamen's Avatar
Quamen
Example:
Impeller speed= (Crank Pulley Ø / Jackshaft Pulley Ø) x (Cog Pulley Teeth behind jackshaft/Cog Pulley Teeth on headunit) x Internal Step Up Ratio x Engine RPM
So....
(5.75"/3.33")x(32/28)x3.54x6500=45,407rpms
You need to calculate the step up ratio at each point (you all ready provided the step up ratio within the headunit derived by dividing the input gear by the output gear).
In the case of my supercharger kit
(7.00/3.25)x(nothing because I don't have a jackshaft)x3.54x6500=49,560
With that in mind my custom supercharger kit should create more boost than the stock Vortech kit due to the larger crankshaft Ø I have.
Old Nov 10, 2007 | 04:44 AM
booger's Avatar
booger
Vortech has a calculator on the web site
Old Nov 10, 2007 | 09:09 AM
cdoxp800's Avatar
cdoxp800
Go here
http://www.vortechsuperchargers.com/support.php
Pick: Impeller Speed Calculator
Click " Go "
Old Nov 11, 2007 | 11:59 AM
rlwjr1's Avatar
rlwjr1
Originally Posted by cdoxp800
Go here
Click " Go "
Thanks, didn't see that there...
350Z_Al
Oct 29, 2020 07:44 PM
Paul.
Oct 16, 2015 07:34 PM
seagrasser
Oct 11, 2015 03:27 PM
Calinismo350z
Sep 14, 2015 04:04 PM
