Stuck between two kits...
Old Nov 18, 2007 | 11:43 AM
XIceDragonX's Avatar
XIceDragonX
Default Stuck between two kits...
I have been debating even after reading all the posts between going with the APS TT kit or the Greddy TT kit. I am looking for good reliability and performance for an almost daily driver. Can anyone please put in some input that own either of these kits, maybe what you liked and disliked about the kit? I personally like the watercooled turbos of the APS kit, but I like the external wastegates of the Greddy kit. My pro's and con's list kinda leveled itself off in noone's favor, and as much as I'd love to put both kits on and leave the one I like on, I don't make THAT much money! All help is greatly appreciated.
Old Nov 18, 2007 | 11:48 AM
Zivman's Avatar
Zivman
There are definitely pros and cons to both kits. I think the watercooled, ball bearing turbos and retaining the stock front beam was the deciding factor for me getting the APS kit. that said, the greddy has external gates which are nice and the greddy also has a bit more head room for power than the APS.
All that said, on a stock block, the APS kit includes everything you need for a true factory TT feel. No piecing things together... not that it is that hard. In the end, the kits are really give and take and very comparable if you weigh the pros and cons of each. In the end, the turbos and retain the stock front brace were really the things that put me over the top in terms of choosing the APS kit
Old Nov 18, 2007 | 11:52 AM
minus500's Avatar
minus500
Well said. If your not going to build the block then I would opt for the APS kit. If your going to build the block in the future, the Greddy will surely take you farther. Both are good reliable kits. Just make sure you have the proper EMS and a solid tune.
Old Nov 18, 2007 | 05:05 PM
XIceDragonX
well the tune is the other part... my ECU is already tuned for N/A =(... so I don't know exactly if I can make up for it with either EMS that come with either of those kits... I am sure a good tuner can, but I believe it would just be better to have a full EMS. I would like to build my block later on... but like I said this is a daily driver, so I would like to have the option to turn down boost and still have it run just as nice, just less powerful, as it does when it is fully boosted.
Old Nov 18, 2007 | 05:30 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Both are awesome kits. You will need a retune regardless of what you decide. I'd run the Unichip that comes with the APS over the emanage but honestly with the options on the market now a UTEC is the least you could do IMO.
Obviously I chose the Greddy-reason for me personally was they have been proven time and time again. They may be older designed snails in comparison not BB/water cooled but you almost never hear of any failing (stock units not upgraded rebuilt units), external wastegates, and power potential. Also, getting parts I Believe is easier as Ive read of BS issues with APS's customer support. And slightly cheaper than APS.
Regardless both are great kits you will be happy with either of them.
Old Nov 18, 2007 | 05:38 PM
XIceDragonX
I thought the turbo's that did come with the greddy kit were ball bearings already.... Although the loosing that front support bracket doesn't really kill me as I have a buddy who can fabricate stuff from his machine shop, and I'd just have him throw me together something. But all in all, I'd love to hear a few inputs from some shops on why they choose to install one kit over the other???
Old Nov 18, 2007 | 05:49 PM
Alberto's Avatar
Alberto
Cranky FI Owner
If I was a shop Id (try to) install the kit I had the biggest margin on Not the best way to go about getting opinions for what is best for YOU....
Old Nov 18, 2007 | 05:51 PM
Weqster's Avatar
Weqster
first up. I run an APS TT and 2.5" exhaust with JWT clutch combo.
They are the only mods ive ever done to the car. APS truely feels, installs and looks OEM. I run the unichip. I havnt been able to fault it. I like watercooled because it lets me turn off the car without fear of coaking. I dont like turbo timers. I like the Aps oil pan. i like the sounds. I like the piping and filters in the gaurds.
I ran a greddy kit on my civic back in the day.
You will be happy with either kit. You probably wont notice the difference because u wont install it urself. Wastegates mean nothing at stockish boost levels. APS has trouble above 12psi, u just upgrade to forged acutators. You wont find any deal breakers with either kit. It comes down to pricing and brand preference.
As far as power output is concerned, you can run an array of GT series turbo chargers on the APS manifolds. Power isnt limited. You will find all kits running on built motors will use different turbo combinations then those that come with the kits.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
Workshop12
Mar 23, 2020 01:45 PM
StateNuke08
Oct 31, 2015 05:01 AM
tm9293
North East Marketplace
Oct 29, 2015 02:58 AM
Beater350z
Sep 9, 2015 03:36 PM
