Got the Vortech back in today
Old Nov 26, 2007 | 02:55 PM
iRide350z's Avatar
iRide350z
Default Got the Vortech back in today
Hey guys,
I just put the Vortech back in and i am a little worried about how it sounds. Here is a quick video but the sound in person is a little more of a high pitched rattle.
http://www.youtube.com/watch?v=LT5bqFa9rLo
Old Nov 26, 2007 | 02:57 PM
iRide350z's Avatar
iRide350z
Also, when I first heard the noise I pulled the filter off to make sure the impeller wasn't loose or scraping the housing.
Old Nov 26, 2007 | 03:38 PM
JCstart's Avatar
JCstart
I'm suspecting your idler pulley bearing...
I had my vortech for 5 months know... 30 days after my initial installation, my Vortech when out ! the bearing inside the Vortech...
They repared it and sent it back to me after 30 days... I install it again and the sound was different... and it's still changing... day after day...
I have actually at 90% the same song as you... but, for me, I'm suspecting the bearings of my idler pulley...
any one else opinion ?
Old Nov 26, 2007 | 03:47 PM
jksstar's Avatar
jksstar
take off the clog belt and you will know for sure if its the S/C or not. I just got one back from Vortech and it sounded alittle like the vid. you posted, it had a very high pitched rattle.
Old Nov 26, 2007 | 04:33 PM
sentry65's Avatar
sentry65
the burninator
I can't see the vids when at work, but what sounded like a pulley bearing to me (from the direction of where I thought the sound was coming from) ended up being the jackshaft bearing
this is all pretty lame of vortech
I wonder if any of their other kits for other cars have been having bad blowers lately or if it's just our type of blower
Old Nov 26, 2007 | 06:16 PM
JCstart's Avatar
JCstart
where is the jackshaft bearing ?
Old Nov 26, 2007 | 06:21 PM
sentry65's Avatar
sentry65
the burninator
inside the jackshaft - the main pulley that turns the jackshaft
Old Nov 26, 2007 | 06:43 PM
iRide350z's Avatar
iRide350z
ok well i'll check the pulley 2maro and see how it sounds. thanks
Old Nov 26, 2007 | 07:37 PM
Hexxum001's Avatar
Hexxum001
Yeah, all these issues are not good. When they work, they work great. But when they go bad, it's such a PITA.
Old Nov 26, 2007 | 07:40 PM
MUZZY's Avatar
MUZZY
im so lucky to have a good one.... 18k miles and still going.
what is your idle set at?
Old Nov 26, 2007 | 07:41 PM
iRide350z's Avatar
iRide350z
its around 900
Old Nov 27, 2007 | 10:56 AM
iRide350z's Avatar
iRide350z
ok, I took off the cog belt and the noise went away...so it must be the s/c again. I also check the oil line and it is working so the s/c is def. getting oil. Should I try to drive it around and see how it sounds or is it going to have to go back to vortech??
Old Nov 27, 2007 | 11:04 AM
Nexx's Avatar
Nexx
if you keep the revs at around 1500rpm does the noise go away or get louder?
Old Nov 27, 2007 | 11:19 AM
iRide350z's Avatar
iRide350z
I reved to 1400-1500rpms and held it there while a friend was listening to the blower. He said the noise seemed to reduce a little, but instead of a slower clanking it was more sped up.
Old Nov 27, 2007 | 11:52 AM
iRide350z's Avatar
iRide350z
I just realized that i took off the idler pulley and the noise went away. That means it could be the s/c bearings or the idler pulley bearings. Its too hard to tell where the noise is coming from, so is there any way for me to check the idler pulley bearings?
Old Nov 27, 2007 | 01:37 PM
MMC Racing's Avatar
MMC Racing
Mine has gotten louder over time to the point of being annoying. When I'm driving 40-50MPH with the windows down traveling near a wall or structure, it sound like a bunch of secada insects outside the car.
Old Nov 27, 2007 | 01:41 PM
iRide350z's Avatar
iRide350z
I just drove around a little, and only really rattles at my idle @ 900rpms. I got into a little boost and everything sound ok. I guess its only the normal vortech rattle.
I do have one other question,
How many quarts of oil total do you guys put in w/ a vortech?
Old Nov 27, 2007 | 01:42 PM
sentry65's Avatar
sentry65
the burninator
I put in 6 with my APS oil pan and oil cooler
Old Nov 27, 2007 | 01:57 PM
iRide350z's Avatar
iRide350z
ok thanks sentry,
If no one has any other suggestions I'll leave it in and just keep an eye on it.
i'd like to raise my idle but i can't remember which years have to be done at the dealership and which ones can be done yourself...(2004.5)???
Old Nov 27, 2007 | 02:01 PM
sentry65's Avatar
sentry65
the burninator
just don't put in 6 quarts if you don't have an oil pan spacer or larger oil pan or oil cooler etc. Otherwise you might end up with some problems by having too much oil
