haltech vs. proefi
Old Feb 23, 2008 | 12:36 AM
  #41
rrmedicx's Avatar
rrmedicx
Any news Mr. Reed on your tuning session's? I would like to know how your comparo when between the ProEFI and Haltech went.
Old Feb 23, 2008 | 06:20 AM
  #42
overZealous1's Avatar
overZealous1
wow!! very impressed with johns skills. didn't have much time yesterday to get all the tuning done. but still by the time i left, the car was making about the smoothest power and the smoothest a/f i have seen. was straight as an arrow!! can't wait to get back in there so we can finish it up with more boost and utilize more of the haltechs features.
Old Feb 23, 2008 | 07:48 AM
  #43
rrmedicx's Avatar
rrmedicx
curious how the tuning was accomplished? dyno or butt dyno. lol. i know mr. reed makes housecalls, just wasnt sure whether or not you reserved dyno time at a local shop. i dont think too many shops like that in ny/east coast.
good luck this time around. share ur results if/when u can.
Old Feb 23, 2008 | 08:19 AM
  #44
Julian@MRC's Avatar
Julian@MRC
Originally Posted by Hal@IP
Enzo as mentioned would be fine, along with Julian @ MRC. Any competent tuner will have no problem with the new Haltech ECU Manager software - it is the best out!
Thanks Hal,
Cant wait for our Haltechs to arrive!!Were gonna make sick power to 8000 RPms on the new motor with BC 3 cams!!!
Old Feb 23, 2008 | 09:39 AM
  #45
redline350ZZ's Avatar
redline350ZZ
Is this the same John Reed that fly's out to Hawaii to tune the big boys?
Old Feb 23, 2008 | 09:52 AM
  #46
IIQuickSilverII's Avatar
IIQuickSilverII
yes
Old Feb 23, 2008 | 10:41 AM
  #47
overZealous1
ya, luckily him and his shop (rrev motorsports) is right in portland here about 6-7 miles from me. i was impressed on how linear he got the a/f. can't wait till we can go further with it.
Old Feb 23, 2008 | 10:46 AM
  #48
overZealous1
it was on a dynojet. we only went to a VERY moderate 6.5psi due to time and boost controller and a couple w/g issues. would ask john to post the dyno sheet, but it really isn't too impressive other than his work on the a/f. also, about 1/3 of my tank had gas in it from 10-12 months ago when i took the car off the road, lol
Old Feb 24, 2008 | 08:43 PM
  #49
overZealous1
btw- i had a bunch of ses codes come up while we were tuning. i cleared them later, and it stayed clear for about 40 miles. then got a couple more, cleared them and has stayed with no trouble codes for now. seems as though you can get away with not throughing codes with the haltech. will decipher the codes if they pop up again.
Old Feb 25, 2008 | 08:02 AM
  #50
RedLeader's Avatar
RedLeader
I can only run about 135 miles before my ECU throws a code with my Unichip.
Luckily, I made a point of sliding through emissions testing about 100 miles after clearing the code
So how many miles on the break-in Scott and what are the wastegate issues?
How do you like the new clutch?
Old Feb 25, 2008 | 08:09 AM
  #51
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
My Haltech is throwing P0011 and P0021, which are back 1 and 2 intake cam codes, but those are to be expected, since the Haltech is changing the intake cams to something other than the stock ECU is expecting. It would be nice if it could intercept those codes and erase them, but that's for the future...
Old Feb 25, 2008 | 08:29 AM
  #52
overZealous1
really was pretty simple. we had one stick open for a couple passes. but it closed itself again. the boost controler i use is the greddy e-01 profec. well, i had the wrong card in the screen. i had in there the non-profec version of the e-01. both were easy fixes.
new clutch feels really good. need to adjust the clutch pedal down though is all. the exedy twin carbon with the upgraded pressure plate spring. i did get caught in traffic though and my oh my did my leg hurt. it is about double stock pedal pressure.
  #53
overZealous1
i do remember seeing those code numbers, but i just cleared then before finding out what they were.
Old Feb 25, 2008 | 08:30 AM
  #54
rcdash's Avatar
rcdash
I believe Osiris can do this now and is a nice complement to the Haltech for troubleshooting (comes with Cipher) and setting idle, rev limiter etc.
Old Feb 25, 2008 | 08:37 AM
  #55
overZealous1
will have to look into it. got a couple crazy idle things going on. granted, we didn't get much time to spend on it. but, idle will sit steady at 1000rpm when first started and for about the first few minutes of driving, then jump to a roving 2000-2300rpm after driving for a few. prolly more time with it will cure it though.
Old Feb 25, 2008 | 08:51 AM
  #56
IIQuickSilverII
Originally Posted by John Reed
Well, late last week I put a ProEFI in my personal car for testing/learning, and so far over the weekend put about 500 miles on it, including driving into some more remote mountain regions doing rally support. ProEFI was a huge help with assisting me in getting it setup (my application is not PNP, and he made some custom tables for me to run my variable cam), and aside from a few minor tweaks to the tune (I have less than 2 hours total into tuning it from scratch), it is back running as good as the tune I had on the previous system (which was pretty dialed). As a dealer, it is wonderful to have both good technical support and also to make suggestions (on a weekend no less) and have them implemented into the software by monday morning.
I will be trying some new stuff as I play with it, but the system is coming along nicely! Jason is really working hard to add the features we want/need, and since the hardware is OEM level stuff, there is no feeling of being a "hardware guinea pig".
Old Feb 25, 2008 | 09:07 AM
  #57
__jb's Avatar
__jb
Z + Rear Seat
Is this just from a cold start?
Does it still happen when starting after the engine is already up to temperature?
Old Feb 25, 2008 | 09:22 AM
  #58
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
Yes, but....thats another $700 that I would rather spend on something else, on the hopes that the Haltech will eventually be able to fix it.
Old Feb 25, 2008 | 09:26 AM
  #59
overZealous1
ya, it does.
Old Mar 4, 2008 | 06:32 PM
  #60
joe~075's Avatar
joe~075
Does anyone know if the pro efi unit is for both the 5 speed a/t and 6 speed m/t.
