Need a fuel return, but how much more power do you think I could make?
Old Dec 20, 2007 | 07:07 AM
Z Esq.'s Avatar
Z Esq.
are you ever gonna send me my heat shield and hardware?
Old Dec 20, 2007 | 07:13 AM
taurran's Avatar
taurran
Originally Posted by jtgli
Another vortech car on Dave's DD dyno put down 390whp and the only thing it had done over me was the fuel return. Am I actually loosing out on almost 30whp because I dont have the fuel return?
Fuel return systems don't make power. They just provide more consistent fuel pressure across all injectors and cylinders. This allows for more precise and consistent tuning.
That being said, you shouldn't need a FRS for that power level. You'd be better off upping the injectors, or doing injectors with a fuel return system.
Old Dec 20, 2007 | 08:49 AM
SpoilsofWar's Avatar
SpoilsofWar
If you were able to get more fuel out of the unmodded fuel basket then the modded one, both while using the same walbro, maybe you messed something up when doing the mod. I would double check the modded fuel pump assembly against another one that has been modded and has produced favorable results (if that is practical).
codek
Sep 28, 2015 03:03 AM
