Easiest way to take off 3.33 Vortech Pulley?
I'm trying to take it off so I was wondering what the easiest way to do it is? I'm trying not to bang out it to hard to please give me suggestions.
Originally Posted by Floridaboy1605
unmount the charger!!!!! take out the 4 or 5 bolts on the bracket move the charger and take off the pulley i did it myself 2 days ago
ha, he said the easiest. Removing the bracket or blower can take over and hour and requires removing the oil lines ect.
Got a strap wrench?
Got a 15mm socket?
Got a big 1/2 drive or breaker bar?
Got 15 min to spare?
Got a 5 or 5.5mm allen wrench?
Got some locktite blue?
The jackshaft is one solid shaft with two threaded ends that accept bolts. You can hold the pulley still with the strap wrench and use a single wrench and 15mm socket to break each bolt loose. Once you get the two bolts out remove the cog pulley. Undo the 4 allen screws (tq'ed like crazy, a ***** to break since they have locktite on them). Remove entire assembly. Once you start pulling the shaft out, the 3.33 pulley will be free to just be lifted off the shaft without touching the blower.
Reinstall in reverse using locktite on the four allen screws. I didnt use any on the 15 mm bolts, i tq'ed them to 40lbs each.
or u cna do it his way and risk not torq'n stuff back and really it took me a total of like 25 min to get the pulley off so yeah idk what u were doing for a hour but it takes no where near that long!!
I saw now way to remove the blower with the bracket still on the motor. The last two bolts were just out of reach. It may just be on the new pulley layout or something, but i wasnt going to risk stripping a bolt or not tq'ing it down enough later on.
350Z_Al
Oct 29, 2020 07:44 PM
seagrasser
Oct 11, 2015 03:27 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
