Vortech SC: back to stock???
Old Dec 10, 2007 | 07:53 AM
G Thizzle's Avatar
G Thizzle
Default Vortech SC: back to stock???
Might be going back to stock soon. I have a the walbro 255 and also my FPR has been modified for the SC... will i need a whole new stock fuel assembly or will the 255 and modified FPR be fine on a N/A car? I know for the most part everything else is just bolt on and my UTEC just needs to be unplugged... thanks in advance!
Old Dec 10, 2007 | 08:01 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
should be fine with the fuel bucket assembly.
what you should be concerned with is the hole in your block for the oil return. Itll need to be fixed or the pan replaced. That is, if you had the return installed there. Ignore this issue if you used an oil pan spacer.
Old Dec 17, 2007 | 06:51 AM
G Thizzle's Avatar
G Thizzle
I did drill into the block for the oil feed line... can that be plugged? I am hoping so unless Vortechs instructions are for keeping the kit on FOREVER....
Old Dec 17, 2007 | 07:10 AM
JET MECH's Avatar
JET MECH
just install a plug. put a small dab of rtv on the threads and you should be fine.
Fixxxercask
Nov 9, 2015 11:10 AM
Depravity
Oct 1, 2015 04:49 PM
Tochigi_236
Sep 27, 2015 03:40 PM
