Those who installed their own FI Kit
Old Dec 12, 2007 | 08:15 PM
BhamZMan's Avatar
BhamZMan
Default Those who installed their own FI Kit
*Disclaimer : This has nothing to do with money, only for my own personal experience *
Was it worth it? I am kicking the idea around of trying to install my own Vortech tuner kit at the beginning of the year. Of course I am going to go somewhere to have it tuned, but I believe that it could be fun/challenging to install my own kit . On a difficulty scale, how hard did you guys find it to be? I am somewhat mechanically inclined, and also have access to any sort of tool I would be needing. I think that with enough time and patience I can most likely have it done...I wouldnt dare to tackle twins, but I think I might be able to do a Vortech. Discuss.
Old Dec 12, 2007 | 08:19 PM
Floridaboy1605's Avatar
Floridaboy1605
Yeah man its not to hard at all just take you time!!!!!!! and remember have fun with it!!
Old Dec 12, 2007 | 08:26 PM
BhamZMan's Avatar
BhamZMan
So which kit have you installed? What did you find to be the most challenging part?
Old Dec 12, 2007 | 08:29 PM
CAYENNE2005's Avatar
CAYENNE2005
Wastegate, for us
Old Dec 12, 2007 | 08:33 PM
carfi179's Avatar
carfi179
If you have no experience with FI installation, patient and some back round in auto mechanic, I'd say NO don't do it. I installed mine it was fun.
Old Dec 12, 2007 | 08:37 PM
gdragon's Avatar
gdragon
same here...just take your time and zip tie all your boost lines....
Old Dec 12, 2007 | 08:40 PM
moog's Avatar
moog
I installed my own Vortech kit, and it wasn't too hard. The hardest part is running into issues like a bolt not coming off or squeezing things into spaces with limited space. If you have a helper, it will be much easier with a second pair of hands.
Old Dec 12, 2007 | 08:43 PM
carfi179's Avatar
carfi179
BTW: Get plenty of latex gloves/mechanic gloves if you decide to do your own install, my hands was a mess after.
Old Dec 13, 2007 | 04:27 AM
Floridaboy1605
i installed my own vortech kit like 5 times now hahahaha def the hardest part is fitting the little POS bolts into those tight spaces!!!!!
Old Dec 13, 2007 | 04:33 AM
QuadCam's Avatar
QuadCam
The vortech is probably the easiest FI kit to install. Go for it!
Old Dec 13, 2007 | 04:36 AM
MUZZY's Avatar
MUZZY
I installed my own vortech, and tell you what 15k miles and its going strong still like day 1. also about the tools situation i doubt you have all the tools for this job.
Old Dec 13, 2007 | 04:59 AM
alan21's Avatar
alan21
installed my own greddy..go for it
Old Dec 13, 2007 | 05:10 AM
coachk's Avatar
coachk
I did my APS TT...just take your time and don't rush things. That way you don't have to go back and fix things.
Old Dec 13, 2007 | 05:34 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
do it, make sure you do it right. then bring it to me for tuning!!
Old Dec 13, 2007 | 05:36 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
Vortech install was a breeze. Just set aside a weekend and go for it. I read the manual so many times and made sure i had all the right tools.
I dont know what bolts theyre talking about being in cramped spots, the only bolts the tuner kit has is 4 for the intake and like 7-8 for the mounting bracket and for for the ic which are all pretty accessible.
Are you adding injetors, utec and a walbro? youll want to get rid of the ur pulley and use either the stock or the fliud dampner type pulley.
Old Dec 13, 2007 | 06:11 AM
Ahsmo's Avatar
Ahsmo
Imakecopies
I would say its worth it. Everytime something does not seem right, you know what to look for rather than trailering the car up to the shop and have them look at it.
Basically, If something isn't right I generally know where to look.
Plus I had a good time installing my kit.
Old Dec 13, 2007 | 06:15 AM
App6MT's Avatar
App6MT
Did you pull your engine?
I really want to do the Turbonetics by myself and it should be no problem. But I want a TT setup more (not sure why cause I don't want a ton of power). I reeeeally want to do the install myself but doing the TT just scares me for some reason.
Old Dec 13, 2007 | 06:30 AM
BhamZMan's Avatar
BhamZMan
I already have the UTEC installed so that isn't an issue. I take it the walbro + injectors arent too difficult to install then? One more thing, why would I want to remove the UR pulley?
Old Dec 13, 2007 | 06:33 AM
eez's Avatar
eez
+1
something will go wrong, it's part of heavy modding like FI. Being able to troubleshoot the issues yourself will save you time and money. That is exactly the reason I did my vortech install, so I could learn and I would be able to figure out problems...of course with the help of the wonderful my350z community
Old Dec 13, 2007 | 06:36 AM
eez's Avatar
eez
walbro is easy and the injectors aren't too difficult. Depending on the injectors, I know RC for sure you will need to get a new clip and solder the connections (easy but time consuming). Make sure you purge the fuel line. Either with Cypher or the manual way described in the 350z maintenance manual.
Also, if you don't have it you will need the MAP sensor for your UTEC.
BTW if you need some 440 injectors I have some I can sell ya for a good price. Just PM me.
Make sure you get a fuel pressure gage!
Get an OIL filter sandwich adapter (I have Greddy) and hook the oil feel line to it, less connections than vortech's setup + their location off the oil pressure sensor tap is a biotch to get to/tighten. + if you decide to get an oil temp sensor you will have another port already there
make your own CAI that puts the filter up front somewhere (mine sits on the FMIC). This will make it easier to clean the filter, otherwise you have 2 choices. 1 damage the filter trying to force it out. 2 take out the SC just to clean the filter.
These are just some things I recently dealt with on my install
