GReddy turbo install, now no start
Hey, i just installed a GReddy turbo kit on an 05 G, and now it don't start. The coils are not getting a signal to spark. I've exhausted everything I can possibly check without a Consult-like scan tool. There are also no codes, all fuses are good, there's voltage to all the sensors. Its getting fuel and the MAF is good.
Think it could be a cam or crank sensor? Thats what i'm leaning toward but i need something to check their patterns. Any ideas?
Originally Posted by QuadCam
what ems are you running? are u using the stock supplied emanage blue?
if so, you possibly wired something backwards.
I've checked the wiring on that over and over again. I thought i might have damaged the wire after where i tapped in and the signal wasn't getting out, but there is voltage, power, and signal after every wire i tapped into. Its cranking, air, fuel, all fuses good. There's even power coming out of all the pins of the ECU there's supposed to be power coming out of. I was starting to think about the immobilizer, but that would prevent the car from even cranking wouldn't it?
As far as for checking the cam and crank sensors, i can only check to make sure they're functioning correctly w/ an oscilloscope right?
Make sure all your grounds are connected. If the coils are not getting a spark then it is not the crank or cam sensors. I am not sure what all you installed, but trace back to what will cause the packs to not spark. Has to be somthing electric and maybe it is the emanage even tho you think you have it wired correctly.
if you did the stock kit, it doesn't do anything with the ignition so those should have been left alone
if you used a harness patch you can remove it and see if it starts with the ECU
There IS a tach adapter that gets wired into the ignition signals to prevent the check engine light from coming on. I've also completely eliminated the emanage to see if it would start just on the ECU by disconnecting the harness and disconneting the tach adapter's signal and ground and still nothing. With it reconnected, nothing. I've gone over all the grounds that i had removed during the installation process and actually checked them w/ a power probe to make sure where they were grounded is actually grounding and that checks out.
This is just f$^king weird man!! I thought also possibly the turbo timer was interfering with something, so i removed it too and still nothing. I mean its pretty straight forward if there's no spark signal there are only a couple things it can be, and i've checked those few things over and over again. I suppose i could continue to check the same things until something dawns on me?
the tach adapter is to give the emanage an rpm signal
I assume you just tapped in the ignition wires and did not cut them and interrupt the signal.
So i got the tranny out and checked the flywheel dowel pins, and it was off by 1 hole. So whether thats the culprit of the no start is still yet to be seen but we'll know for sure once we put everything back together.
Did you try the trick, of pulling the crank position sensor out, and starting the car? That will tell you if it was, indeed, the flywheel.
Sorry for the late response guys! We've been busting to get this car back on the ground. .. Turns out it was Flywheel! All we have to do now is put everything back on, Cats and Exhaust and this bad boy will be back on the ground! I'll be sure to take some pictures soon its down.
Still a few things we want to add to this ie; gauges, oil cooler kit. then it can get its massive widebody put on!
I'd like to thank everyone for helping me out with this, great community! thanks everyone! :biggthumpup:
I'll keep everyone posted!:thewave:
