Built Motors: What Oil/Filter are you using???
Originally Posted by QuadCam
This is the one I use. It is a longer than stock filter....for the M45 and FX45. It fits the VQ perfectly. This one on the right is Stock size.
current lubricant is moly lube, lol. till she breathes life again, then do a 50/50 mix of castrol synthetic and castrol organic.
1. D350z10..................Motul 15w50 300v oil, standard nissan filter.
2. eagletanggreen.........Motul 15w50 300v oil, standard nissan filter.
3. romey.....................Motul 15w50 oil
4. IIQuickSilverII...........Mobil1 10w30 full synt oil, PE filter
5. Thawk408................Castrol 10-40 oil, standard nissan filter.
6. AboostedG...............Motul 15w50 300v oil, standard nissan filter
7. Dutchboy.................Motul 15w50 300v oil, standard nissan filter
8. Sharif@Forged...........Motul 15w50 300v oil, standard nissan filter
9. Philthy.....................Motul 15w50 300v oil, PE Filter
10. danisr1...................Motul 15w50 300v oil, standard nissan filter
11. Zivman...................Amsoill 10w40 oil, standard nissan filter for the 4.0litre VQ (pathfinder and Xterra)
12. Jay'Z......................Mobil1 0w40 oil, K&N Filter
13. USN HM 350z...........Redline 20w50 oil, K&N Filter
14. Jeremy@Forged........Motul 5w40 8100, standard nissan filter
15. RED RIDER...............Mobil 0w-40 full synth and mobil filter
1. D350z10.................Motul 15w50 300v oil, standard nissan filter.
2. eagletanggreen........Motul 15w50 300v oil, standard nissan filter.
3. romey....................Motul 15w50 oil
4. IIQuickSilverII..........Mobil1 10w30 full synt oil, PE filter
5. Thawk408...............Castrol 10-40 oil, standard nissan filter.
6. AboostedG..............Motul 15w50 300v oil, standard nissan filter
7. Dutchboy................Motul 15w50 300v oil, standard nissan filter
8. Sharif@Forged.........Motul 15w50 300v oil, standard nissan filter
9. Philthy....................Motul 15w50 300v oil, PE Filter
10. danisr1..................Motul 15w50 300v oil, standard nissan filter
11. Zivman..................Amsoill 10w40 oil, standard nissan filter for the 4.0litre VQ (pathfinder and Xterra)
12. Jay'Z.....................Mobil1 0w40 oil, K&N Filter
13. USN HM 350z..........Redline 20w50 oil, K&N Filter
14. Jeremy@Forged.......Motul 5w40 8100, standard nissan filter
15. RED RIDER..............Mobil 0w-40 full synth and mobil filter
16. PalFX.....................Amsoill 10w40, standard nissan filter
Chris,
I was running the Motul 5W40 300V; it doesn't show great results in Used Oil Analyses. Most people seems to get higher than normal values for Iron, Aluminum, and LEad when using any of the Motul 300V oils. (all from wear) Those oils are not designed for extended street use. They are designed for short-term, track use. Ester Synthetics (300V) tend to absord moistures more than other oils. I am not trying to say that the 300v is aweful; I'm just saying that it is not all that it's cracked up to being.
I am running Rotella T-Synthetic 5W40 now. Alot of guys are running "turbo diesel" oils now. I'll tell you how the oil tests out when I get the Used Oil results back from Blackstone.
It's ironic you say that about Motul, yet by looking at the list majority are using Motul.... after hearing about your samples I'm scratching my head.
Sharif, how did you samples come back on the 15w-50 Motul?
17. DJ SMITTY..............Eneos 0w50 switched from Motul 15w50, standard nissan filter
well keep in mind that those of us with built motors, especially who run them to high rpms, are not necessarily after the longest change intervals. In fact I change mine more frequently now that its built vs when it was stock
Originally Posted by maximumsportZ
Andrew,
I am staying away from it after seeing the UOA results that have been posted so far. Redline seemed to fair very well according to the UOA and now the Shell Rotella T-syn does also.
Originally Posted by USN HM 350Z
I would like to see all the people running the Motul on FI built motors send their samples off for UOA and post the results.
That is how I am now. I change very often. very often my oil still looks not far off from when I poured it, still translucent that is (darker though)
Andrew,
I got my oil analysis back (see "oil analysis thread" in the engine and drivetrain forum) on the Rotella T-Syn. MY Aluminum and Iron levels (both indicators of wear) dropped significantly from my previous UOA when using Motul 300V.
I believed the hype about Motul 300V. It's $13 per quart.....It's got to be the best.
Do some UOAs for yourself using different oils......and make your own conclusions as to what works for you. It was suggested that I try the Rotella T-Syn as an inexpensive oil to try while waited for the results of my Motul UOA to come back from Blackstone. When I saw the high levels of iron and aluminum from the MOtul sample, I decided to leave the Rotella in the engine and see how it works out. I am please with the results of the Rotella and I refilled with more on this oil change. After 3500 miles or so, I send this sample in also to see the results.
Agreed, I hear great things about Redline 10w-40.
Originally Posted by craigo'sznprgrs
I prefer royal purple 10w 30 with a standard nissan oil filter. I haven't seen but one person giving the royal purple any love.
BTW Edited first post with the offical list. STICKY THIS ROME.
