Oil On Plugs !!!!!
Old Dec 25, 2007 | 06:11 AM
JCstart's Avatar
JCstart
Exclamation Oil On Plugs !!!!!
Hi guys !
yesterday, after I removed my Vortech to return it for a bearing change...
I decided to change my plugs... after 11 000 miles...
and on one plug, I founded oil OVER the threads....
and on the otherS...a very little oil on the threads...
any opinion on this ????
I think it was not enought torqued.... but... how know !
THANKS!
Old Dec 25, 2007 | 06:21 AM
moog's Avatar
moog
Leaky valve covers...one of mine was like that too when I changed the plugs. Seems to be somewhat common.
Old Dec 25, 2007 | 06:27 AM
westpak's Avatar
westpak
SFZCC
^^+1 unfortunately you can't buy the seals you have to replace the whole cover
Old Dec 25, 2007 | 06:50 AM
JCstart's Avatar
JCstart
What !!!! the whole cover !!!
is there any probs if I don't ?
Old Dec 25, 2007 | 07:17 AM
failsafe306's Avatar
failsafe306
Yeah- oily plugs.
Old Dec 25, 2007 | 07:26 AM
Blackbird CPV35's Avatar
Blackbird CPV35
that happened to me too, on both of the rear spark plugs. I just cleaned out the area and put it back together. I drove for 5000 miles with the vortech on and 2 oily plugs without a hitch
Old Dec 25, 2007 | 07:54 AM
JETPILOT's Avatar
JETPILOT
I have a used valve cover for sale if your interested. it has good seals.
JET
Old Dec 25, 2007 | 09:48 AM
thawk408's Avatar
thawk408
I thought you could buy them seperate? I know they come in the Nissan gasket rebuild kit.
Old Dec 25, 2007 | 10:01 AM
SpoilsofWar's Avatar
SpoilsofWar
I know for certain you can buy the valve cover seals seperately. I just did it a few months ago. Got them from Performance Nissan of Duarte.
Old Dec 25, 2007 | 10:22 AM
westpak's Avatar
westpak
SFZCC
there are two diffeent type of gaskets, one which comes in the gasket kit is what goes around the edge of the cover, then you have three individual rubber seals that go around the holes in the cover that go over the spark plug tubes, those you cannot buy separately
Old Dec 25, 2007 | 10:26 AM
thawk408's Avatar
thawk408
Ah yes. I forgot about that. *** it just use RTV!
Old Dec 25, 2007 | 01:11 PM
SpoilsofWar
Touche
I was even thinking myself after I posted: "Why would oil leaking out around the perimeter of the valve covers cause oil to be on the coil pack shaft and plug?"
Just to make things completely clear though, you dont need to buy the whole gasket kit to get the valve cover gaskets. Performance Nissan sells everything seperate.
Old Dec 25, 2007 | 03:42 PM
JCstart's Avatar
JCstart
hummm... I'm not sure if I want to get in this...
Old Dec 25, 2007 | 04:51 PM
thawk408's Avatar
thawk408
Its easy, dont be scared!
Old Dec 26, 2007 | 04:35 AM
JCstart's Avatar
JCstart
ok !
I will use a light film of rtv ultra gray around the plug tube seals...
But, do I have to change the one which comes in the gasket kit is what goes around the edge of the cover... or I can simply reuse it ?
thanks !
Old Dec 26, 2007 | 05:22 AM
westpak's Avatar
westpak
SFZCC
you can reuse it
Old Dec 26, 2007 | 07:22 AM
JCstart's Avatar
JCstart
ok, I will !
thanks to you guys !
help is always appreciated !
Old Dec 26, 2007 | 09:40 AM
failsafe306
Watch those torque specs when re-installing the valve covers.
Old Dec 26, 2007 | 06:08 PM
JCstart's Avatar
JCstart
oh ! as I see... I must remove the upper and lower plenum to remove the valve cover...
hummm...
Old Dec 26, 2007 | 06:53 PM
westpak's Avatar
westpak
SFZCC
hummm...
yeap
