Stillen Idler Pulley
Old Jan 2, 2008 | 09:02 PM
MulhollandDrive's Avatar
MulhollandDrive
Default Stillen Idler Pulley
For those with early Stillen SC kits, there is a new idler kit for the non-supercharger belt. This is the same idler that had a "spacer" update. The new idler kit is machined and seems to solve the belt squealing and belt eating behavior of the non-supercharger belt. Hopefully, when combined with the 6 rib supercharger belt upgrade, belt reliability will be good.
Old Jan 3, 2008 | 06:14 AM
superchargedg's Avatar
superchargedg
Damn Noobs
When i had the stillen i just bypassed that damn noisey idler pulley.Mine went bad and made a ton of noise so i just tried using the original belt and had no problems after.
Old Jan 5, 2008 | 05:25 AM
G35GL450GSXR750's Avatar
G35GL450GSXR750
superchargedg,
After you remove the idler pulley, did any of belts slips/squeaks even with your stage 4 kit? Cause i was thinking doing the same thing you did. Thanks
Old Jan 5, 2008 | 02:22 PM
superchargedg
Damn Noobs
Originally Posted by G35GL450GSXR750
superchargedg,
At first yes they did but i tightened the belt a little at a time and i got it to stop.It is hard on the belt but i just couldnt stand the noise anymore and that litlle idler also screwed up the factory adjuster pulley.
Old Jan 14, 2008 | 06:49 PM
Nforce1's Avatar
Nforce1
Now that winter has come and the cold weather has arrived, my car is squeeling like an 89 civic! I had this same issue last year just after I had Stillen change out all my belts. I drove back out there and they just reached in tightend a screw with 2 turns and it all went away. Now its been about a year since then so the belt needs to be tighted... which I tried to do, with great failure. The screw behind the alternator is the one I tried to tighten but was unable to do so with angle and lack of leverage I had... Anyone have any ideas to get rid of this squeel??
Old Jan 14, 2008 | 07:01 PM
reptile718's Avatar
reptile718
Mine squeals while driving for about 10min every morning from that damn pulley and at idle it sounds like there is something wrong with my engine Its really embarrassing and makes the car sound like junk! I was thinking about just removing it, good to hear someone else has done it with success. BTW how much is the new idler pulley kit?
Old Jan 14, 2008 | 07:21 PM
Nforce1's Avatar
Nforce1
I think its $400?
Old Jul 27, 2011 | 05:56 PM
Matt-z-'s Avatar
Matt-z-
Which idler pulley do you remove... The one with the triangler bracket?
Old Jul 28, 2011 | 03:25 AM
superchargedg
Damn Noobs
The one in the picture in the middle and just use the stock belt and not the one stillen supplied.
Old Mar 9, 2024 | 02:18 PM
03Boosted 350z's Avatar
03Boosted 350z
Where can I get that pulley?
Fixxxercask
Nov 9, 2015 11:10 AM
Bodyboarder81
Nov 2, 2015 12:17 AM
Bodyboarder81
Sep 21, 2015 06:23 AM
EnjukuRacing
Sep 11, 2015 08:34 AM
EnjukuRacing
Sep 11, 2015 08:30 AM
