Vortech Custom CAI
Old Jan 6, 2008 | 06:34 PM
Lady Jax's Avatar
Lady Jax
Drive For Pole
Smile Vortech Custom CAI
We're bacccccccck!
Vortech.......great service, lots of help with correcting the KERBLAMMO, took a bit of turn-around time, supplied lots of little bits and pieces to re-accomplish the install in a 'tighter' fashion,etc., etc., etc. (positive public service announcement provided for all of the beyond-the-call-of-duty customer service that Vortech mustered up despite being slightly overwhelmed with everybody else's problems).
While we had everything taken apart we decided to install the custom CAI to make changing the air filter easier. We used the parts from the Injen CAI (the short hard pipe and the long silicon coupler) with the Vortech air filter. It all fits in behind the stock bumper cover and foam cushion (with just a little bit of trimming to provide clearance). We did have to 'customize' the Wolo horns just a bit but they still work fine.
As you can see, I finally got that embedded picture thing figured out. I hope that this provides some ideas on doing a better Vortech CAI
Old Jan 6, 2008 | 09:12 PM
Mr_pharmD's Avatar
Mr_pharmD
looks good but not sure if ure going to get much better air there with the bumper blocking most of the cold air. If u had a g35 then that for sure would work great but I think u might get better air flow running near the wheel walls.
Old Jan 6, 2008 | 11:19 PM
JAM3Z's Avatar
JAM3Z
Phenom
that Shadow Sports front end is gonna look sick!
Old Jan 7, 2008 | 05:51 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
very cool, we will have to copy that idea and see how it does on the dyno!!
very thorough and good job like always
Old Jan 7, 2008 | 05:59 AM
helldorado's Avatar
helldorado
It should at least help with heat soak and intake temps. IIRC, GTM did a similar intake setup on one of their Vortech vehicles.
Yeah, found it.
Old Jan 7, 2008 | 06:01 AM
booger's Avatar
booger
looks great lady jax
a larger filter may help with air flow
Old Jan 7, 2008 | 07:13 AM
Biochem7's Avatar
Biochem7
Regular
trash that Vortech filter and put a larger cone filter on.
Old Jan 7, 2008 | 07:49 AM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
In any case its much better than having the filter sucking up 150'F air from behind the radiator.
It should not only lead to lower air temps at the outlet of the intercooler, it should also increase the boost a tiny bit.
Old Jan 7, 2008 | 07:53 AM
Hydrazine's Avatar
Hydrazine
Jeremy,
A comparative dyno test will need to have the hood closed to see the effect of hot air on compressor efficency.
Just a FYI.
Old Jan 7, 2008 | 08:14 AM
MUZZY's Avatar
MUZZY
Not to jump off trrack, but I'm having a hart time removing my filter. I need to change it bad!
anyone know how to take it out w/o taking the whole assembly out?
do I just **** the air filter up and $hit?
Old Jan 7, 2008 | 08:29 AM
EnjukuBG's Avatar
EnjukuBG
Enjuku Racing
The turbonetics kit is set up the same way.
Old Jan 7, 2008 | 08:32 AM
iStan's Avatar
iStan
ZR
Try to be careful, but yes.
Old Jan 7, 2008 | 10:32 AM
Quamen's Avatar
Quamen
Looks nice!
Old Jan 7, 2008 | 11:02 AM
Biochem7's Avatar
Biochem7
Regular
Here's my version
Old Jan 7, 2008 | 12:17 PM
RA11325's Avatar
RA11325
Looks good, here mine:
Old Jan 7, 2008 | 03:16 PM
MOTOWIPEOUT Z's Avatar
MOTOWIPEOUT Z
Looks pretty good IMO. I like what your did with the intercooler, is that just painted black or did you use a thermal dispersant coating? Don't give anyone a heartattack with those horns. LOL.
Old Jan 7, 2008 | 05:03 PM
MrJax's Avatar
MrJax
Fights On!
The wife's busy for the next few days and she asked me to watch over her thread. So with your kind permission I'll do my best to answer all your questions/thoughts.
As to the airflow, we had been a bit concerned about that but it seems to do well on the initial test runs. We had thought about cutting the foam cushion just in front of the filter to provide a channel so that air will flow away from the high pressure area in front of the intercooler and over the aluminum beam and back to the filter. Given the relative vacuum created by the supercharger impeller the pressure differential should easily drive sufficient air through the intake. This should also still protect from 'hydrolock'.
Old Jan 7, 2008 | 05:07 PM
MrJax's Avatar
MrJax
Fights On!
It is at the body shop as we speak and hopefully will be ready tomorrow. We are going to utilize the wife's professional photography and PhotoShop skills (apparently she is some sort of national authority on photography/PhotoShop or something like that) to generate some good quality pic's and we will post them on the 'Exterior/Interior' area as soon as possible. Stay tuned to this 'Bat Channel'
Old Jan 7, 2008 | 05:08 PM
MrJax's Avatar
MrJax
Fights On!
Thanks, Jeremy. Hope your holidays were good to you. Did you see our sig?
Old Jan 7, 2008 | 05:11 PM
MrJax's Avatar
MrJax
Fights On!
Yeah, we agree, booger. I think, in the end, we will use the filter that came with the Injen, it is about twice the size and hopefully will still fit.
