Joint in MD 5/16" spacer???
Old Jan 9, 2008 | 04:28 PM
str8dum1's Avatar
str8dum1
Default Joint in MD 5/16" spacer???
Hey guys,
I was redoing my gaskets today, and looking at my MD plenum spacer, i noticed a joint. Now if you twist or tension the joint, it most definately separates.
Is that joint something I should be concerned about aboutm esp considering I have a known vacuum/boost leak?
Here are some pics. Is this what you guys have on yours also?
Thanks!
Attached Thumbnails Joint in MD 5/16" spacer???-md-spacer-joint-1.jpg   Joint in MD 5/16" spacer???-md-spacer-joint-2.jpg
Old Jan 9, 2008 | 04:35 PM
davboy's Avatar
davboy
oops I was thinking of a different kind of joint.
Old Jan 9, 2008 | 05:42 PM
str8dum1's Avatar
str8dum1
Ok, i found out from Tony from MD, that those joints are supposed to be there. I assume to save metal in the manufacturing process. Either way on my setup, my vacuum leak went away when i removed the spacer. That coulda been due to reinstallation/retorquing however, but I;m in no rush to swap back to the spacer. Too many other things to get right 1st.
Old Jan 9, 2008 | 06:27 PM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
The joint is hydraulicly pressed and swaged. It should be absolutely rigid and inflexible.
If it has any give in it, the swage had to have been damaged in some way. Possibly droped, bent or some kind of shipping damage.
PM me your adress. I'll send you a replacement.
FromGtoZ
Sep 20, 2015 03:41 PM
torchkc
Sep 11, 2015 08:26 PM
