Single Turbo
Old Jan 15, 2008 | 08:00 AM
  #141
phat04350z's Avatar
phat04350z
Originally Posted by Black Guy
Yup, depends on alot of things. Which ever route you take, make sure you do it RIGHT.
Right on!
Old Jan 15, 2008 | 08:15 AM
  #142
damojo2003's Avatar
damojo2003
Originally Posted by Robert_K
But they are out there. They are in Sigs, sticky's, linked etc...
No argument there. But what would it take for a mod to set up a post that is filled with these links to discussions. That is what we did and it help alot.
Old Jan 15, 2008 | 08:21 AM
  #143
EnjukuBG's Avatar
EnjukuBG
Enjuku Racing
Not a bad idea, but you can get alot from searching for Single Turbo.
Old Jan 15, 2008 | 08:26 AM
  #144
JAM3Z's Avatar
JAM3Z
Phenom
Originally Posted by phat04350z
Which goes back to my original thing! FI forum should be closed.
I'm not trying to be a dick, but as you've been a member here for a whopping 2 months, I'm not exactly sure where you get off telling us that the FI forum should be closed. There's a wealth of knowledge here, the fact that you seem to be having trouble comprehending it is not our problem.
Old Jan 15, 2008 | 08:46 AM
  #145
Robert_K's Avatar
Robert_K
Didn't Go Cheap
If you go back threw my post I was very much a supporter of N/A cars. Still am. However reading through the F/I threads give me the information I needed to start my JWT build. Now I didn't have everything perfect but I had an large idea of what I needed and the cost of it.
Old Jan 15, 2008 | 09:31 AM
  #146
r0mey's Avatar
r0mey
Originally Posted by taurran
Actually, I believe most people here don't fully understand the differences between twin and single turbos. Two is not always better than one.
i 100 percent agree with this
Old Jan 15, 2008 | 09:37 AM
  #147
Robert_K's Avatar
Robert_K
Didn't Go Cheap
From my own N/A & F/I Thread:
IMO, One isn't better than they other. Same with N/A vs. F/I & Turbo vs Supercharger. Everything has its pluses and minuses. You need to build your car around your wants and needs. IE: Someone that is a major autocrosser is going to invest in suspention, brakes, & stay N/A vs the drag racer that wants a high output HP car to complete the 1/4 as fast as posible. Also, and this is the biggest kicker, is money. I'm sure if we all could afford a Ferrari we all would own one. Some people just can't, for whatever reason, afford to completely build their motor and do a major twin turbo build.
All-in-all, I don't think one way is better than the other. Guess that is why I just enjoy seeing a fellow Z owner enjoying thier Z however it is built*.
*To an extent.
Old Jan 15, 2008 | 09:39 AM
  #148
JAM3Z's Avatar
JAM3Z
Phenom
Can you elaborate please. No sarcasm here, I'm just curious to learn about the finer/less known facts about the difference between TT/ST.
Old Jan 15, 2008 | 09:45 AM
  #149
Robert_K's Avatar
Robert_K
Didn't Go Cheap
First thing that comes to my mind is weight. A TT kit has more components that add considerable amount of weight. As we all know weight & heat are our enimes.
Old Jan 15, 2008 | 09:52 AM
  #150
ncparamedic's Avatar
ncparamedic
Prodigal Son
+1 Reading is your friend..
Old Jan 15, 2008 | 09:54 AM
  #151
dutchboy350Z's Avatar
dutchboy350Z
Finally some go
Nice job stalker! In case you did read those, those threads were specific to the Z. Same with this one. A turbo on any car pretty much is the same on ANY car. This thread is Z specific, spacer is Z specific, exhaust is Z specific, what breaks on 1st on a Z is Z specific, should I continue? I only post when I know I have the right answer. In this case I am asking why people choose single over dual. If you have an issue leave and dont post in my thread.
Old Jan 15, 2008 | 09:58 AM
  #152
damojo2003's Avatar
damojo2003
Agreed, but if you are just starting out modding your car and don't know anything. Searching for single turbo, everything that contains turbo pops up is a bit overwelming and makes it difficult to find an answer. I am just suggesting, take it or leave it, simple thread with a sticky that has links to common topics to jump start the learning process. Now if some one needs additional information like ideal AFR and timing for a turbo, then they can search for it.
  #153
dutchboy350Z
Finally some go
To be honest search in FI for a single turbo and let me know how many responces you get. A ton, its not worth it unless I know who made the kit, the power I am looking for. I even tried to search for why people choose single turbo and I either got none or way to many cuz the word turbo is in every thread. The search PHPBB provides is weak. People that are newer into cars here are either afraid to come here because of the responses or cant find there answers. Like I stated its best to either provide a link to help or just give em an answer or just say FI for HR motor only and lock out everything else. I am glad you see its a tough forum but as a mod you should fix that
There are 124 threads in the F/I section related to single turbos. You're one lazy bastard.
https://my350z.com/forum/search.php?searchid=5181488
Old Jan 15, 2008 | 11:52 AM
  #154
taurran's Avatar
taurran
Of course there are MANY factors involved when sizing a turbo(s) for any particular application, but there are obviously tradeoffs with the decision between the two setups. I'll admit the MAIN factor on our cars is the engine configuration and lack of space for a turbo and routing of piping, not the simple fact that you must run a crossover pipe. Once there are more options for squeezing a larger single turbo and piping into the car (PL ST) there will be a lot more people singing praises of the single turbo setup, I believe.
Another main factor in deciding the spool characteristics of the two properly sized turbo setups (twin vs single) are mass of the center rotating assemby (turbine wheel, compressor wheel, shaft), and the inertia behind the wheel once it is spinning.
Turbos aren't 100% efficient. Two smaller turbine wheels require less exhaust gas energy to spin, but also suffer from having to move overall more massive wheels each which half of the exhaust gas energy. The larger turbine wheel on a single turbo is able to take advantage of the full displacement of the motor, and the complete amount of exhaust gas energy is exerted on one turbine. As you go for more and more power, you will be forced to go with larger turbines on both setups. As you increase sizing on a twin turbo setup, it becomes increasingly less efficient to spin twin turbines each with half the motor's exhaust gas energy. A single turbine is able to take greater advantage of the output of a particular sized motor by utilizing the full amount of exhaust gas energy, and more often through a manifold which allows for higher velocity flow. As you go with larger turbos on both setups, the spool advantage on twin turbos will decrease exponentially unless you add more displacement.
Twin turbos incorperate two smaller turbine wheels which take smaller volumes of air (less energy) to spin, while a larger turbine wheel will move slower but gain more momentum as it moves. This is due to the property of inertia, which means that a larger object will resist movement but gather more momentum as it moves. For this reason the twin turbo setup with the smaller rotating assemblies will spool faster, but the single turbo will be more efficient and spool quicker once it begins moving. Twin turbos will generally have a greater range of efficiency at lower boost while larger singles will enjoy greater efficiency at high boost.
There's also the issue of clearances (gaps in parts/wheel fitment). Turbos are built with the same clearances regardless of size, so with two smaller turbos you have effectively twice the area tolerance which has a greater impact on the efficiency of the turbo setup. A single larger turbo is built with tighter clearances overall compared to it's wheel and housing size. It will be more efficient for this reason as well.
I'm no engineer so that's pretty much it in layman's terms.
That being said, there's really no "right" or "wrong". If you want faster overall spool but less efficient high boost power, go with twins. If you don't really care about spool and want higher boost and power, then go with a single. Of course it's easier said than done on our cars. With little room and a V motor the big single is no easy task.
I hope that all made sense. I typed it out pretty fast.
Old Jan 15, 2008 | 12:00 PM
  #155
JAM3Z's Avatar
JAM3Z
Phenom
Very informative, thanks Craig, not sure I agree about the momentum part, but interesting nonetheless.
Old Jan 15, 2008 | 12:21 PM
  #156
damojo2003's Avatar
damojo2003
That was the answer that I wanted to know since a guy in a performance shop was talking to me after he cleaned my injectors. He said big turbo for top end for fast 1/4 mile times, that is what he wanted and he delt with the lag. You just confirmed to me that this is correct.
Old Jan 15, 2008 | 01:06 PM
  #157
DanielW's Avatar
DanielW
turbonator?
Old Jan 15, 2008 | 01:57 PM
  #158
zmedic16's Avatar
zmedic16
+1k on what taurran stated. if u want a track car get the jwt/greddy/aps wich all see full spooling at around 2500-3200rpms depending on boost level. that's why most track dedicated 350z are tt. now if uwant a highway monster single turbo kit such aS the powerlab is the way to go...spool time might b 3500-4200rpms or even higher but power potential is much greater. I'm a noob as well.... correct me if I'm wrong. I'm sure taurran can clarify.
Old Jan 15, 2008 | 02:55 PM
  #159
phat04350z's Avatar
phat04350z
I mist have stated that how many times in this thread and others. The search function is not that great.
Old Jan 15, 2008 | 02:58 PM
  #160
phat04350z's Avatar
phat04350z
Lol funny thing is when I say closed I mean no more questions to be asked. Its more of a storage area. Look at what myself, damojo2003, and Black Guy have stated in these past few postings. We all agree that there is a ton of information but the search is horrible, and there is no way to find this information. Have you tried to search "single turbo"? And then look for one that says why people choose that over a dual. You seem to point the finger at me yet look around...
