Haltech Launch Control
Old Jan 22, 2008 | 01:41 PM
kevinapex's Avatar
kevinapex
Originally Posted by nfo184
where can i get it? and how much does the whole kit cost?
You can get the Haltech through Hal @ Injected Performance, as for the other switches and wire, I just put it together from scratch. There's only about $10.00 worth of parts.
There are many diffrent ways of doing the clutch switch, you could add a relay on the existing lower limit switch on the clutch. Just use its signal to control the aux. rev. limiter.
Hope ths answered your question.
Kevin
Old Jan 22, 2008 | 03:14 PM
Alberto's Avatar
Alberto
Cranky FI Owner
If it doesnt build boost its pretty pointless IMO. Just a secondary rev limit for those that feel they need it off the line. Your switch is nicely done though.
Old Jan 22, 2008 | 03:31 PM
rcdash's Avatar
rcdash
It doesn't build boost, at all, at any rpm set point?
Old Jan 22, 2008 | 03:34 PM
kevinapex's Avatar
kevinapex
I set at 3k it made 1psi. I havn't messed around anymore than that.
Old Jan 22, 2008 | 03:48 PM
DJ SMITTY's Avatar
DJ SMITTY
CIN Motorsports
When Hal was messing with mine in November I believe it made close to 6 or 7psi at 5000rpms
Old Jan 22, 2008 | 03:57 PM
rcdash's Avatar
rcdash
^that's more like it. Can you get any kind of tires to stick launching at 5k rpm in first gear with 6-7 psi snapping in?
Old Jan 22, 2008 | 03:59 PM
DJ SMITTY's Avatar
DJ SMITTY
CIN Motorsports
^^^haven't tried yet. My motor is out of the car right now haha.
But I can't imagine any traction what so ever launching already at 6-7 psi on street tires.
Old Jan 22, 2008 | 05:34 PM
thawk408's Avatar
thawk408
Can you set up the Haltech to use the 2-step for a real purpose....to build boost? I want 10 pounds when I leave the line.
Why is everyone so scared to build boost with the 2-step? Yes it hurts the life of the turbo, but its not like its going to kill it the next day. I wish this community wasnt so scared to break ****. Get some decent sidwalled ET streets (or whatever tires you prefer) and let her eat. Supras (just using it as an example) use 2-step all the time on big sticky tires and they cut 1.3-1.4 60s.
Old Jan 22, 2008 | 05:38 PM
kevinapex's Avatar
kevinapex
Jesus! 10 psi will DR's even hook up? talk about bustin parts!
Old Jan 22, 2008 | 05:42 PM
thawk408's Avatar
thawk408
On true slicks and DRs it should hook aslong as you have a good sideway. Good sidewall meaning a 28x15. Guess we will find out how the drivetrain likes it.
Old Jan 22, 2008 | 05:47 PM
kevinapex's Avatar
kevinapex
You're a madman!, good on ya!!
Old Jan 22, 2008 | 05:49 PM
InjectedPerf's Avatar
InjectedPerf
Supras have much stronger stock axles!!!
Old Jan 22, 2008 | 05:51 PM
seunset350's Avatar
seunset350
A two step that doesn't build boost, Is like going to the strip club... your wasting your time, your money, and your just going to have to do the work yourself after.
Seriously... whats the point... I would only recommend using a 2-step with good tires, and then use it for what it is meant for, to build the boost.
Old Jan 22, 2008 | 06:15 PM
eagletanggreen's Avatar
eagletanggreen
Got Track!!!!!
I love what this Haltech will be capable of but till then Fcon is still the choice for me. It controls my meth (you guys need to get this $hit), I have a nice working 2 step that build boost at the line, and will have the flat shift working very soon.
I think Alberto has a video of me launching @5K with Dr's... Not sure thou?
Kev!
Nice work getting this fabbed up! It's better than guessing what rpm your at while your at the line.
Old Jan 22, 2008 | 06:53 PM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
Kev!
Haltech does have a Nitrous/Meth output now, and has a nice working two-step Setting it at 3000rpm on a twin 60-1 kit isn't going to build a lot, but as DJ Smitty posted above, his car makes 6-7psi on it almost instantly with the Greddy twins. The reality, most people aren't needing the extra spool at the line due to current traction limitations.
For Kevin, my advice is start low and turn it up at the track each launch until it is perfected.
Trust me, having personally pulled multiple 1.3 60's in a 350z, I love the hard launch! But no sense abusing things just to induce more wheel spin. And speaking of wheel spin, we have something in the works for that as well
Old Jan 22, 2008 | 07:04 PM
eagletanggreen
Got Track!!!!!
Awesome!!
That is def good new's! Might have to change the ECU on my next rotation.
Old Jan 22, 2008 | 07:09 PM
kevinapex's Avatar
kevinapex
Come on now Hal, throw up a vid. lets see it rip!!
Kevin
Old Jan 22, 2008 | 07:13 PM
  #38
eagletanggreen
Got Track!!!!!
Kevin
+1
Throw it up!
Old Jan 22, 2008 | 08:50 PM
  #39
thawk408's Avatar
thawk408
Kev!
What is flat shift? I was leaning more towards the Haltech for the cam timing control, it has basicly all the features of the fcon, and its cheaper.
Old Jan 22, 2008 | 09:30 PM
  #40
thawk408's Avatar
thawk408
I know, but it will still be fun breaking ours!!!
