My plugs after 17k miles... SC/Built engine.. Opinions..
Lemme know what ya think.. Fouled or wtf?? Oil was soaked in the furthest right plug bank..
This is the passenger side.. from right to left is the front to rear..
Driver side right to left is from front to rear bank..
Another pic of passenger side..
Comments....
Comments....
the white tips definitely look like a lean condition... but, 17k on plugs running the boost levels you have been is a bit harsh... i am set on changing mine at 10k or below... especially since i'm running 2 step colder plugs... are you're 1 step colder? remember, they're more susceptible to fouling due to the lesser spark...
EDIT - the more i look at the plugs, the more i see just normal fouling and corrosion from harsh use... if were truly lean, the ceramics would be white, as well...
Originally Posted by Jeremy@Forged
the white tips definitely look like a lean condition... but, 17k on plugs running the boost levels you have been is a bit harsh... i am set on changing mine at 10k or below... especially since i'm running 2 step colder plugs... are your 1 step colder? remember, they're more susceptible to fouling due to the lesser spark...
Originally Posted by Jay'Z
No defi wideband = none in my z....
Innovate DB9 standalone = $279.
JET
Originally Posted by JETPILOT
= I have no idea what my A/F is which isn't good and leaves you reading tea leaves to figure out what is going on.
JET
JET
define "soaked in oil" - I don't see oil deposits in those pics. Don't count the threads
http://www.dansmc.com/Spark_Plugs/Sp...s_catalog.html
Looks to me like your plugs are a bit on the cold side, or your not that hard on the car...but that should be fine
It seems you can forget the Innovate. Everyone around here can't seem to get one to work more that 24 hours. And Innovate is no help at all. I'm think of going AEM. What other options do I have? Don't say Fcon.
JET
Get the Tuner Reg wideband from Turbo XS. If your running the UTEC it will interface and data log. You can run a display gauge off the UTEC. Contact Quadcam. He did this.
JET
JET
JET
JET
The gaps were set at .032 says NGK-R PLFR62 11 on the plug...... I dropped in some new iridiums one step colder with the gaps set at .038....
Whats the closest it looks to the chart????
Do you think this http://www.dansmc.com/Spark_Plugs/7.html
As far as the color of the plugs you are only going to see the way the car was running when it was last started. IE: It was last idling so it may show signs of it being a little lean. More damage to the plug would be a different case.
