how to loosen belts for stillen sc install ?
just need some quick help...im in the process of installing my stillen sc, and i need to loosen the oem belts in order to get some of the stillen pulleys on. ive removed the bolts from the oem pulley in order to remove that, but i still need to get the belt off. how do i loosen the belt? i think its the main one, the serpentine i believe. thanks!
you loosen but do not remove the 14mm nut in the center of the pulley. Then there is a 12mm i believe adjustor bolt facing the ground. turn it counter-clockwise to loosen the belt.
no offense intended at all, but are you sure you can make it thru the whole installation of the supercharger system?
