AAM Surge tank & Pump---Need Help
Old Jan 27, 2008 | 02:50 PM
rrmedicx's Avatar
rrmedicx
Default AAM Surge tank & Pump---Need Help
Anyone ever install one of these AAM Surge Tank & Pump set-ups? see link below.
I bought one and I have no idea where to mount it. Under the car or in the glove box on top of the OEM fuel access cubby???
If anyone has it installed would you mind sharing any pics, or ideas of better ways to install, improvements made, etc.
Also looking for some feedback on the unit. If there is anything that needs to be done to the unit before install.
What is interesting about the install is that in the instructions provided by AAM, they show a diagram (see link above) where from the surge tank there is an overflow port that leads back to the main OEM fuel tank. I don't even see a port on the surge tank other than the feed in port and the port out connecting to the bosch pump. Other than that, there is no other port.
Am I supposed to weld a bung to create an access back to the main tank?
Any feedback is greatly appreciated.
Old Jan 27, 2008 | 02:54 PM
tig488's Avatar
tig488
i think it bolts up underneath the rear of the car.
Old Jan 27, 2008 | 03:07 PM
rrmedicx's Avatar
rrmedicx
I would love to see some pics of exactly where...Got any?
Old Jan 27, 2008 | 03:45 PM
JAM3Z's Avatar
JAM3Z
Phenom
Correct. I just saw a pic of it floating around not too long a go, but yes, it mounts up right under the rear of the car.
Old Jan 27, 2008 | 03:54 PM
rrmedicx's Avatar
rrmedicx
I hope that by using the greddy TT exhaust, it won't interfere with the install of this unit.
Old Jan 27, 2008 | 04:01 PM
rrmedicx's Avatar
rrmedicx
A little birdy just sent me some pics. Here it goes, but I still don't see where the overflow fits in.
Old Jan 27, 2008 | 04:12 PM
rrmedicx's Avatar
rrmedicx
I just caught this photo and noticed a second port just behind the one showing on top. Look closely and you might see a second port just peeking out behind the one facing the top of the unit.
Old Jan 28, 2008 | 03:00 PM
phunk's Avatar
phunk
CJ Motorsports
the plumbing in that map is no good. you will run into problems. you need to return from the regulator back to the surge can. then have the surge can overflow to a return correction kit in your stock pump assembly.
time to bust out the welder
Old Jan 28, 2008 | 03:16 PM
rrmedicx's Avatar
rrmedicx
Hey CJ,
Can you recommend which fitting to weld into the surge?
Where is best to weld, maybe one of the ends? and then I will need to devise some plumbing back from the surge to the OEM fuel return fitting. Thanks.
Maybe something like this?
Can be found on this site: http://www.jegs.com/webapp/wcs/store...10002_89728_-1
Would this work in conjunction with your stage 2 Return Fuel System?
Old Jan 28, 2008 | 03:48 PM
phunk's Avatar
phunk
CJ Motorsports
that bung will work fine, you should weld a -6 bung anywhere on the can, it doesnt really matter, and run the return from the regulator there. use the fitting currently on the top center of the can to go back to the return bulkhead on the OEM assembly.
Sure, you can make it work with the S2 kit. just plumb it all up as required... the bosch pump would pump into the hardpipe, and have the return line go to the AAM can
Old Jan 28, 2008 | 03:55 PM
rrmedicx's Avatar
rrmedicx
Hey CJ,
What size is the an fitting for the hard line by the OEM pump for your stage 2 which feeds the motor? Is it -6 or -8 an? I was thinking it was an -8 and the fitting size for the return mounted on the pump, is that a -6an? I just want to make sure I order the correct fittings to make everything work.
Thanks.
I'm guessing the feed lines are -8an and the return lines are -6an? Not too sure though.
Old Jan 28, 2008 | 03:57 PM
phunk's Avatar
phunk
CJ Motorsports
the hardpipe has female -8 ends on it. The return hose is a -6. The return bulkhead is a -4. There is a -4/-6 adapter on the end of the return line for that.
Old Jan 28, 2008 | 04:46 PM
kevinapex's Avatar
kevinapex
Did that come out of co? might be my old one!
Here is a link that shows picts. how I mounted it. It wouldn't fit the way AAM set it up because of APS exhaust.
Kevin
https://my350z.com/forum/showthread....&highlight=sfr
Old Jan 28, 2008 | 05:07 PM
rrmedicx's Avatar
rrmedicx
Thanks Phunk! I appreciate the help.
Hey Kevin...Unfortunately the reference to your thread from last year has pictures that I believe expired and don't show up anymore.
If you wouldn't mind posting them up on this thread, I would appreciate any help I can get. I am thinking about adding an inline fuel filter to the feed from the bosch into the hard-pipe. Any objections/ideas.
Old Jan 28, 2008 | 05:28 PM
kevinapex's Avatar
kevinapex
Let me try and get the picts back up, I had filter pict. also.
Kevin
Old Jan 28, 2008 | 05:44 PM
kevinapex's Avatar
kevinapex
Old Jan 28, 2008 | 06:25 PM
kevinapex's Avatar
kevinapex
Old Jan 28, 2008 | 06:26 PM
rrmedicx's Avatar
rrmedicx
PM'd you Kevin.
Old Jan 28, 2008 | 06:31 PM
rrmedicx's Avatar
rrmedicx
Originally Posted by kevinapex
Looks as though from the fuel filter it splits to 2 lines. I assume that you have these 2 lines go up to the front and to each fuel rail.
Old Jan 28, 2008 | 07:01 PM
kevinapex's Avatar
kevinapex
This pict. is of my existing CJM twin pump set up. The 2 -6 lines run from the twin pumps, -8 feed rails.
I used the same filter with the AAM surge and 044 pump.
