Vortech Boost Leak
Old Feb 1, 2008 | 01:18 PM
Dreamsmith's Avatar
Dreamsmith
Default Vortech Boost Leak
i am running vortech with 3.12 pulley, my boost hits ~6psi then fails down to ~4.5psi at around 5.5k rpm, at that time i get a whistling sound not same as the one which normaly comes out of the supercharger, this has a higher pitch, i tried closing the BOV little more but no use, before this i was hitting 8-9 psi.
can someone tell me if this is a belt slip or a boost leak somewhere, or my BOV is damaged?
Old Feb 1, 2008 | 01:27 PM
str8dum1's Avatar
str8dum1
how did you try closing the bypass valve? with the screw or by pushing on the valve itself?
if it doesnt go away with a tighter belt, you'll have to look/listen for a leak. pretty tough to do.
Luckily my boost leak was from my bypass valve and was replaced by vortech when my bearings went bad.
Old Feb 1, 2008 | 04:44 PM
booger's Avatar
booger
Did you do any work on the plenum? Add a spacer or a new plenum ? Most boost leaks with a SC wwill be there . Check your couplers also .
Old Feb 2, 2008 | 12:18 AM
Dreamsmith's Avatar
Dreamsmith
i used the screw to close the BOV but no use, do vortech BOV get damaged often?
i a have spacer but am sure its not leaking from there, it was properly sealed.
everything was working fine before 2 days, no leak and i was hitting the correct boost!!
Old Feb 2, 2008 | 04:02 AM
Barzten1's Avatar
Barzten1
Im thinking its the plenum also. Happened to me too. Try retightening those bolts and see if it goes away.
Old Feb 2, 2008 | 05:02 AM
booger's Avatar
booger
check all your vacuum lines . The one going to the BOV first
Old Feb 2, 2008 | 06:14 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
there are a lot of places you can get boost leaks on these cars. i always say to take everything off and reinstall it again...
it works!!
Old Feb 2, 2008 | 08:21 AM
kevinapex's Avatar
kevinapex
Almost sounds like belt slip, is the belt good and tight?
Old Feb 3, 2008 | 11:58 AM
booger's Avatar
booger
it works!!
A little to much trouble for most of us . I just hook this baby up to the IC pipe right before the bov and then cap off the exhaust . Pressurize the whole system and walla , you found your leak .
Old Feb 3, 2008 | 01:20 PM
harogts's Avatar
harogts
i had a similar problem, and it was the bpv. there's an o-ring that goes on the valve, it fell off and it wouldn't hold the boost
Old Feb 3, 2008 | 02:51 PM
str8dum1's Avatar
str8dum1
ya mine fell off before it was tuned. i think that lead to my boost leak. fortunately vortech sent me a brand new bypass valve along with my warrantied blower.
Old Feb 3, 2008 | 07:38 PM
Barzten1's Avatar
Barzten1
Happened to me also.
Old Feb 3, 2008 | 08:52 PM
Triji's Avatar
Triji
make sure to check and clean your air filter also... I was only getting 7psi and I thought it was a boost leak at first as well until I took a look at my filter... I cleaned it and then regained my 9.5psi
Twenty4
Jan 17, 2016 01:20 PM
Fixxxercask
Cooling System
Nov 5, 2015 03:21 AM
derekinthez
South East
Sep 28, 2015 06:35 PM
