Used Turbonetics Kit Please help!
Old Feb 10, 2008 | 01:45 PM
  #61
rrmedicx's Avatar
rrmedicx
Got any pics of the new pipe by chance Ed. I used to have a photo, but its not on this laptop.
Old Feb 10, 2008 | 01:48 PM
  #62
Fingers's Avatar
Fingers
Originally Posted by IntenseFab
The weld looks fine, if it were a poor/contaminated weld it would have started at the center of the weld. and went on from there (kind of like a cracked windshield) it starts in a spot and weakens the surrounding material and therefore spreads...
Contamination in welds do break in the bead but undercutting(to much heat) and overcutting(not enough heat) beads break at the edge just like his. Like you said, it could be a thousand variables but a weld should never break on the bead or along the bead, both are signs of poor welding.
To the OP, it looks like this has happened with these kits before, I'm sure turbonetics will take care of you. Hopefuly they also use some kind of system in their manufacturing to find the common denominator on the kits with broken welds, I'm willing to bet most of them were done by the same welder.
Old Feb 10, 2008 | 01:51 PM
  #63
350 Rookie's Avatar
350 Rookie
well i dont really have proof of purchase. this thing was installed deff less than a year ago though. The installation took place last summer. It only has 5k miles on the turbo kit and its my DD. I dont know what to show you except to talk to the shop and theyll tell you the date of installaion.
also, when you just said that it eliminates 2 pipes into one, in the newer version. Will that still work with the old version kits or do i have to upgrade.
also, i dont mean to tell you what to do or how to run the company but since it was clearly a welding issue, i think turbonetics shoudl replace the pipe regardless of the warranty. Kind of like a recall. All te old pipes should have came back and new ones should have been shipped out considering we have put trust and several grand into this kit.
Old Feb 10, 2008 | 01:53 PM
  #64
doug's Avatar
doug
if you bought the Kit from VTR and VTR installed it.. your VTR invoice will be proof of purchase enough
  #65
Ed 718's Avatar
Ed 718
BRAVEHEART
I can get you a picture from work but I don't have any myself. If you still have my email addy send me a email so i can get you the pic. Our servers were updated and I lost all of my contacts.
Old Feb 10, 2008 | 01:57 PM
  #66
Ed 718's Avatar
Ed 718
BRAVEHEART
Correct we should be able to look it up in our computers or Vinny or Christine may even have a copy of it. I work directly with the Vinny Ten guys so I will touch bases with them.
The new revision does not need any modification to install and like I said it elimintates two pipes, the accordian looking pipe ( 21200 ) and the U looking pipe into one pipe with a flex joint that is braided so it allows more movement.
Old Feb 10, 2008 | 02:06 PM
  #67
350 Rookie's Avatar
350 Rookie
i would like a picture as well. post it up here so everyone can see. or you can pm me. either way.
Old Feb 10, 2008 | 02:10 PM
  #68
Ed 718's Avatar
Ed 718
BRAVEHEART
It won't be till monday as a matter of fact I'm gonna start loading some files into my laptop just incase I need to reference something on the go.......
Old Feb 10, 2008 | 02:21 PM
  #69
350 Rookie's Avatar
350 Rookie
hey ed. when were these changes made to that kit and are there anyother changes?
Old Feb 10, 2008 | 02:32 PM
  #70
Ed 718's Avatar
Ed 718
BRAVEHEART
Other than the water cooled bearing housings nothing.
Old Feb 10, 2008 | 02:40 PM
  #71
350 Rookie's Avatar
350 Rookie
can i get a swap with that too if im still under warranty. I dont want the turbo to go bad in another cuople of thousand miles. lol
Old Feb 10, 2008 | 03:02 PM
  #72
doug's Avatar
doug
i don't think the turbo's ever went bad.. it was just an upgrade to the regular kit..
Old Feb 10, 2008 | 04:00 PM
  #73
r0mey's Avatar
r0mey
im happy to see ED is here i knew he would take care of you man.
Old Feb 10, 2008 | 04:24 PM
  #74
350 Rookie's Avatar
350 Rookie
Whoa, dont get to happy. I'm still not taken care of.
Old Feb 10, 2008 | 04:29 PM
  #75
JAM3Z's Avatar
JAM3Z
Phenom
Wow so many negative posts on this thread.....Geez
Here's a positive post....
Greddy FTW J/K
I gotta say, for all the controversy with the turbonetics kit, it seems like for the most part, they do a pretty reasonable job taking care of their customers, which one might not be able to say for a company like APS.
Old Feb 10, 2008 | 04:42 PM
  #76
Zivman's Avatar
Zivman
Greddy FTW J/K
but then again, things don't seem to fall apart like they do on TN kits
Old Feb 10, 2008 | 05:11 PM
  #77
JAM3Z's Avatar
JAM3Z
Phenom
are you referring to GReddy or APS?
Old Feb 10, 2008 | 05:25 PM
  #78
Zivman's Avatar
Zivman
i am just saying I would rather have a quality setup vs a POS with a better warranty.... to me a guaranteed POS is still a POS
Old Feb 10, 2008 | 05:35 PM
  #79
JAM3Z's Avatar
JAM3Z
Phenom
Yeah that is very true. Regardless of a part being warranted or not, when it breaks, you're still going to be out of a car for some length of time.
Old Feb 10, 2008 | 06:03 PM
  #80
r0mey's Avatar
r0mey
LoL you will be taken care of im sure of it.
BTW how much power were you making when this happened do you have a dyno sheet you can post?
