Question about 3.8L motors
Originally Posted by thawk408
Maybe for extreme rev most of that is preferable, but to take it to 7500-8k just be sure whoever built your motor knew what they were doing and include a good size cam with good springs.
Originally Posted by go-fast
everyone wants to talk about when their turbos come on but people forget to consider if my motor revs freely and yours doesnt my boost can come on much later and still kick your ***.if we are 1000 rpm apart and i rev 1500 rpms quicker whose boost is better?
Originally Posted by JAMEZ
So what advantage would their be to the 3.8L stroker over a sleeved 3.8L motor?
You have a very good question James, as mentioned shorter stroke and lighter components lead to an engine that can rev higher, but with our engines(VQ35) and a stroker kit (especially our GTM 3.8L) it isn't going to be limiting how high you can rev the engine since most people stay under 8,000 rpm anyway.
Bearings, piston, and thrust washer coatings are all very good idea for a high rev application. Valve train is a very important factor and a big cam is going to be a must to make some good top end power, if that is what you are after.
Cost wise, it is about the same to go with a sleeved short block with a 100mm bore or our 3.8L stroker short block, price difference is less than a couple of hundred dollars.
In an unsleeved engine, you are going to have much better heat dissipation than a sleeved engine due to the heat transfer properties of aluminum vs iron. Although with significant upgrades to the cooling system (including a GTM 82mm radiator) we were able to keep coolant temps under 90 degrees Celsius on a 4.2L stroked and sleeved engine that was being drifted on a road course all day, keep in mind while drifting airflow to the radiator is minimal so this was very impressive.
At the end of the day it boils down to what you want, me? I wanted the best of both worlds, So I went with the 3.8L stroker crank (87mm stroke) and sleeved my engine with a 100mm bore which gave me a 4.1L engine that can still rev high. I also added into the mix a set of our GTM Stage 3 cams (282's) and Stage 3 heads, since I will be revving my car to 8,000 rpm so we can see what it does
For a bit of safety I also added a Nismo oil pump to the build so I can rev the motor high for years to come
We have three 3.8L stroker engines coming out of our shop between now and the next few months, including my G35, so this should help give you more information on the characteristics of a 3.8L stroker engine.
Here are a couple of pictures of our GTM 82mm Competition Radiator:
Hope this help,
-George
GT Motorsports
Hope this help,
-George
GT Motorsports
I remember I was talking to George@GTM a while back about the setup he is running on his G35. He is running a 3.8L stroked motor with bored-out sleeve, which brings the total displacement 4.15. Although the cost for this setup is way up there, it seems like this would be a fantastic compromise for revs and midrange torque.
edit: wow, i totally missed George's post. internet pwns me i guess.
I have our GTM Stage 3 heads which come with the following compenents:
GTM Valve Springs (single)
GTM Exhaust and Intake Valves 1mm oversize
GTM Ti retainers
GTM Keepers
etc.
-George
GT Motorsports
GTM Ti retainers
GTM Keepers
etc.
-George
GT Motorsports
Is the 3.8 stroker around 5k? How do you figure it is as much as a sleeved 100mm piston motor when sleeves are around 1k. I know there is more machining with the sleeves, but not thousands of dollars.
James You don't want a stroker motor!
All your questions will be answered when I give you a ride in my car. ALL!!
Save your self some $$$
... Go with Pistons, Rods, and Cams... Thats ALL you need!
Yup-but think back to September 06' (when I built) and it was the "thing to do" over 550whp, now its not needed in 99% of builds. Many 700+whp stock sleeve cars. Community has progressed
At any rate, knowing you're driving habits and style, if you were to do it all over again, would you instead go with a setup with a built (but unsleeved) bottom end? It still seems to me like a lot of people are still doing sleeves, I know MaximumsportZ has the Dartons on his car.
That is true. I did a lot of reading over your thread before I sent my own car off. Its crazy how things have changed in 18 months.
I would still sleeve, but thats because people like me need extra "strength" and we stil have issues
Plus-dont let the original build #"s fool you, thats just me playing nice.
Anyways, all this built motor stuff is a super long way off for me, because at the moment school is kicking my ***. But, I do like learning stuff like this regardless of when I'll be able to get the work done.
I've always wondered about those original numbers
Are you at stock bore with your sleeves? If so, why didnt you decide to do overbore?
Stock bore-numbers are legit, but no where near whats capable. Who knows what it would have done....
