Question about 3.8L motors
Originally Posted by JAMEZ
99% of the guys with trucks around here couldn't care less about performance. However, diesel trucks can be nasty out of the hole. From a roll though, they don't stand a chance.
Originally Posted by George@GTM
in the high performance realm there is no such thing as over building, the stronger you make an engine the longer it will last and more efficient it will be.
GT Motorsports
GT Motorsports
Originally Posted by go-fast
i don't agree with this statement,the 30% rule applies to performance builds.for longevity of a high stress engine all parts should be designed to withstand your planned h.p. plus 30%.any less is risky and anymore is overbuilding.the life span of a 30% motor and a "every part in the book"engine is identical barring outside influence.the only difference is cost to build.
That is your opinion, and I respect it. Just as my previous statement is my personal opinion. I have nothing to gain by recommending someone to "overbuild their engine" Obviously if I didn't believe it was the best thing to do I wouldn't have gone the course I went with my engine, which would have saved me thousands.
We will just have to agree to disagree
-George
GT Motorsports
That is your opinion, and I respect it. Just as my previous statement is my personal opinion. I have nothing to gain by recommending someone to "overbuild there engine" Obviously if I didn't believe it was the best thing to do I would have gone the course I went with my engine, which would have saved my thousands.
-George
GT Motorsports
-George
GT Motorsports
thats fine, but just for clarification you believe a 500 hp motor deserves a 1500 hp rod regardless of the fact a 1500 hp rod weighs considerably more than a 750 hp rod?
I am all about the lightest AND strongest components possible
-George
GT Motorsports
No, I believe that my GTM rods, that are lighter than any after market rod available for the VQ35, and are capable of 350hp per rod, are the way to go
-George
GT Motorsports
-George
GT Motorsports
Originally Posted by thawk408
Because it makes him more money.....
If you have the money and dont care to spend it, then by all means over build it. I am a firm believer of using just what is needed to make the engine strong, but dont see a reason to spend money on parts which are not needed.
EDIT:
Its also probably different for me, because I like to do my own work so if something breaks I just pay for parts. So that makes it a good bit cheaper.
EDIT:
the reason you overbuild is for the security reasons. when going FI you are bound to run into problems, breaks, cracks, leaks, or whatever...it WILL happen. when you overbuild you have that sound security in mind that your car is better built to handle the added stress...
so i would say its more of a reassurance thing
EDIT:
EDIT:
Yes....that is why its called over building. Things can happen, but doesnt mean it always will. Again depending on the purpose of the car, determines what I would put into the engine. This is my opinion and my opinoin only. Just because you put the biggest and badest parts in the engine doesnt mean it will last longer or be better.
I have a question that hasn't been addressed at all yet. I know in the early stages of our builds we were doing 8.5-1 compression ratios. Now I've seen 9.4 cr. What are some of the benefits and downsides to having a higher compression ratio. I'm assuming you can get a little more engine power and throttle response but does it put more stress on the rods then.
I don't know how I did not answer your question, You asked a general question about a hypothetical scenario, and I answered with a specific answer that relates to what I actually did with my build.
When build a VQ there aren't that many choices for Rods, Pistons, Crank, etc.
Do I recommend Pauter rods to people? No because I believe they are too heavy and not needed based on what we know today.
I do not want to derail this thread any further off topic, if you would like to discuss how I feel about selecting components to build an engine PM me and I will send you my number so we can chat, I love to talk about cars
As I stated, I have nothing to gain from people "overbuilding" their cars. To be honest I don't really care what you decide to go with for your engine, because its your engine - not mine. All I am doing is voice my honest opinion based on what I know, If you would like to take it that is fine, if not that is fine also.
Oh and to answer your hypothetical question posted above, I would obviously choose the 750hp rod that weighed considerably less(lightest and strongest for me), but according to you this would still be overbuilding, since all I would technically need is a 500hp rod, which would weigh even less than the 750hp rod, hypothetically.
Have a nice night,
-George
GT Motorsports
Have a nice night,
-George
GT Motorsports
Have a nice night,
-George
GT Motorsports
Have a nice night,
-George
GT Motorsports
I think you guys are assuming a 3.8L bored out engine is the same as a 3.8L stroked engine, it is not. When you have a stroked engine, the piston travel speed is increased creating a higher amount of exhaust gases coming out of the engine. This will create, in a turbo car, a much more responsive and "torquey" engine. The turbos will be spooled faster, hence making more power down low.
As an example I would like to share this dyno graph of our 3.8L stroker engine coupled with a APS Twin Turbo system, running only 10psi. Show me a 3.8L sleeved engine with 100mm bore making 500rwhp at only 10 psi with a APS kit (this is not a extreme kit btw)
So this shows that if your budget allows, a stroker engine would be the best avenue to take for your build, also in the high performance realm there is no such thing as over building, the stronger you make an engine the longer it will last and more efficient it will be.
Do you want to make 650rwhp on a dyno one day? or do you want to put down that power every day? That will also determine which approach you should take for your build.
Good luck!
-George
GT Motorsports
Good luck!
-George
GT Motorsports
Good luck!
-George
GT Motorsports
Good luck!
-George
GT Motorsports
