Question about 3.8L motors
Old Feb 14, 2008 | 02:09 PM
  #141
GTM's Avatar
GTM
Vendor - Former Vendor
Originally Posted by thawk408
Would only sleeve an NA motor if I was going 4.2
I agree, best bet would be a non-sleeved 3.8L stroker, cost effective, and awesome response.
-George
GT Motorsports
Old Feb 14, 2008 | 02:11 PM
  #142
JAM3Z's Avatar
JAM3Z
Phenom
With some aggressive cams and head work, that would be a very unique setup. If you're looking to set yourself apart from the crowd, that'd be one way to do it.
Old Feb 14, 2008 | 02:30 PM
  #143
__jb's Avatar
__jb
Z + Rear Seat
Originally Posted by sentry65
just look at some shortblock pictures of a stock VQ35 and some darton sleeved short block pictures and you'll see
Thanks for the pictures.
It looks like the sleeved block has more water jacket passages at the deck of the cylinder block. Is that what you mean by open and closed deck? I don't see how that could be a side effect of putting in sleeves, unless extreme decking of the block is required to shave down the sleeves.
That was my original plan.
It seems like the additional displacement added by the 100mm bore would be really attractive on an NA motor. I didn't realize there were so many negatives.
Old Feb 14, 2008 | 02:37 PM
  #144
JAM3Z's Avatar
JAM3Z
Phenom
I'm not sure I'd call it negatives, but is a definite increased cost/benefit trade-off as you make more and more elaborate modifications to the car.
Old Feb 14, 2008 | 03:20 PM
  #145
sentry65's Avatar
sentry65
the burninator
the sleeves don't really have more water passages
the stock one is totally open around the cylinders while the sleeves fill in all that space and then have those little holes going down the sleeves instead of having the whole area available for coolant
Old Feb 14, 2008 | 11:06 PM
  #146
Nathan's Avatar
Nathan
The open deck is closed of at the top by the cylinder head & head gasket with just a few small holes & slots to let the water flow through.
With the Dartron sleeves there is a groove machined in the top that mimics
the open deck & the holes you see drilled in the top line up with the holes in the head gasket & head.
The water flow & capacity is the same OE, the only difference being the flange at the top of the sleeve that makes it a closed deck.
Old Feb 19, 2008 | 04:57 PM
  #147
__jb's Avatar
__jb
Z + Rear Seat
I understand the technology, I'm just having trouble with the terminology. So the picture below is a stock, OEM, open deck.
And the picture below is of Darton sleeves that are closed deck.
Seems like the sleeves would keep the cylinder wall straighter and rounder with the extra metal near the top of the cylinder.
Thanks for the help.
Old Feb 19, 2008 | 05:32 PM
  #148
Nathan's Avatar
Nathan
Correct.
Most people, but not all fit the Dartron sleeves so they can bore them out to increase the capacity of the motor. Others feel that the open deck is weakness on an all out FI motor.
The open deck has a thin steel sleeve fitted on the inside of the bore which will only allow about a 20 thou overbore.
Old Feb 19, 2008 | 11:04 PM
  #149
srt4-no more's Avatar
srt4-no more
-George
GT Motorsports
So the dyno graph of the 3.8L APS twin's was non-sleeved correct?
Old Feb 20, 2008 | 12:46 AM
  #150
JETPILOT's Avatar
JETPILOT
Of course keep in mind for the sleeves to keep the bores straighter and rounder you need to have a problem with them being distorted in the first place. I think it has been proven that there is no need for sleeving the block for less than 600whp.
JET
Old Feb 26, 2008 | 08:23 AM
  #151
gothchick's Avatar
gothchick
Has anyone thought through the dampening dynamics of a stroked engine? Even if it's balanced/ blueprinted, it's still going to need dampening for longevity sake.
https://my350z.com/forum/showpost.ph...9&postcount=26
https://my350z.com/forum/forced-induction/337947-mrc-first-cracked-crankshaft.html
